Your basket is empty
Duracell Digital Camera Battery Charger
Quicklinx: 75DTWS00 Mfr#: DR5700D-UK
Duracell Compact Battery Charger
The Duracell Compact Battery Charger can fully charge your camera battery in under 2 hours. The charger is supplied with a mains wall adapter for use around the home. This charger has an LED light which indicates the status of a charge at any time as well as in built safety features meaning it will never over charge your battery.
Duracell battery charger
Battery charger
United Kingdom
AC 230 V
3 years warranty
Nikon EN EL1, EL10, EL11, EL12, EL2, EL5, EL8
Battery charger
United Kingdom
AC 230 V
LED indicator, short circuit protection
Limited warranty - 3 years
