Your basket is empty
Drobo SAN for Business B1200i 12TB (6x2TB) 12 bay Hard Drive Array
Quicklinx: 9Q33WS00 Mfr#: DR-B1200I-1A31/12TB/RE
Drobo, makers of the award-winning data storage products for businesses and professionals, offers a line of sophisticated yet easy-to-use and affordable storage solutions for small and medium businesses. Built on the proven BeyondRAID technology, Drobo delivers advanced capabilities such as thin provisioning and dual drive redundancy, usually reserved for more expensive enterprise solutions. Drobo SAN storage for business is designed to provide reliable and high performance storage to servers running business-critical applications such as back up, email, and server virtualization. Drobo B1200i connects seamlessly to your existing TCP/IP network and utilizes the industry-standard iSCSI protocol to provide simple, consolidated storage for your servers.
Drobo SAN for Business B1200i - hard drive array
Hard drive array
Enclosure Type
Rack-mountable - 3U
Total Array Capacity
12 TB
Gigabit Ethernet
Host Channels
3
Maximum LUNs
255
6 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS-2
Storage Controller
SAS (SATA 6Gb/s / SAS 6Gb/s)
Hard Drive
6 x 2 TB HDD SAS 6Gb/s - hot-swap
Microsoft Windows Server 2008 R2 x64 Edition SP1, Apple MacOS X Server 10.5.8 or later, Microsoft Windows Server 2003 R2 (32/64-bits) SP1, Citrix XenServer 5.6
AC 120/230 V - 50/60 Hz
Power Redundancy
43.61 cm x 55.5 cm x 13.21 cm
21.3 kg
Hard drive array
Enclosure Type
Rack-mountable - 3U
Chassis
6
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS-2
Storage
12 TB
HDD Array External Interface
Gigabit Ethernet
Host Channels
3
Maximum LUNs
255
Storage Controller
SAS (Gigabit Ethernet)
Channel Qty
12
Interface Type
Data Transfer Rate
600 MBps
Max Storage Devices Qty
12
Hard Drive
HDD - hot-swap
6 x 2 TB
Interface Type
SAS 6Gb/s
Spindle Speed
7200 rpm
Expansion Bays
12 (total) / 6 (free) x hot-swap - 3.5"
3 x Ethernet 1000Base-T - RJ-45 , 1 x Ethernet 1000Base-T (management) - RJ-45
Software Included
Drobo Dashboard
UL, TUV, VCCI, BSMI, CISPR 22 Class B, cUL, CB, ICES-003 Class B, MIC, RoHS, WEEE, FCC Part 15 A, ACA, REACH
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
43.61 cm
55.5 cm
13.21 cm
21.3 kg
10 °C
35 °C
20 - 80%
