Product
Drobo 5D 5-bay Storage Array with Thunderbolt / USB 3.0
Redefining Professional Storage. Again.
Quicklinx: 8785WS00 Mfr#: DRDR5A31
Type: Storage enclosure
HD Size: 3.5"
Power Supply: Power supply
£528.34 ex VAT
£634.00 inc VAT
Redesigned from the ground up to meet the data storage needs of today's media creators and demanding professionals, Drobo 5D builds on the fully automated functionality of previous Drobo arrays by adding blazing-fast performance.
Leveraging cutting-edge Thunderbolt and USB 3.0 connectivity--along with the innovative use of solid state drives (SSDs) --Drobo 5D is the highest-performing personal storage array on the planet.
Not only is Drobo 5D fast, but it's easy-to-use, expandable, flexible, and protected--exactly what's expected from a Drobo. You can safely store and edit photos and videos as well as store and back up personal data.
Data Protection and Expandability Made Simple
Built on award-winning BeyondRAID™ technology with single- or dual-drive redundancy, Drobo 5D protects your data without any user interaction, even in the event of multiple drive failures. Drives can be added or hot-swapped on-the-fly for storage expansion with zero downtime. If you're running low on space, the wraparound lights on the front tell you what to do. Just add a drive in an empty bay or remove a smaller drive and replace it with a larger one.
Power of Thunderbolt and Flexibility of USB
Thunderbolt I/O technology provides performance that's up to 5x faster than the previousgeneration Drobo S. This allows you to move large amounts of data in a fraction of the time it used to take. Drobo 5D is equipped with dual Thunderbolt ports for daisy chaining. Connect up to six Thunderbolt devices and/or a non-Thunderbolt monitor at the end of the chain. With six Drobo 5D arrays in a chain, you can have up to 96 TB of usable capacity. And, the bi-directional 10 Gbps performance of Thunderbolt allows all devices in the chain to achieve maximum throughput.
Drobo is the only storage array that offers Thunderbolt AND USB 3.0. This latest generation of USB also offers high-performance connectivity and is backward compatibility with any computer running compatible versions of Mac OS X or Windows.
Capacity AND Performance
Data-Aware Tiering technology, usually reserved for business-class storage solutions, is also available in this desktop Drobo. It intelligently uses the high-performance flash in SSDs to accelerate performance of the storage array, allowing applications such as Adobe Premiere and Apple Aperture fast access to data.
If getting the fastest performance possible is your thing, you can also load up every drive bay with SSDs. Drobo gives you the flexibility to choose.
Power Protecting Your Critical Data
Drobo doesn't just protect you from a drive failure, but also from potential data loss after a power outage. Often found only in arrays that cost tens of thousands of dollars, Drobo 5D includes a battery that protects all data in memory, or cache, that is, data on its way to the drives.
When power spontaneously goes away, the battery keeps the Drobo alive long enough for the data to be written to nonvolatile storage. The battery recharges itself and lasts for the life of the product.
  • Data protection and expandability made simple
    Built on award-winning BeyondRAID technology with single- or dual-drive redundancy, Drobo 5D protects your data without any user interaction, even in the event of multiple drive failures.
  • Power of thunderbolt & flexibility of USB
    Thunderbolt 2 I/O technology provides performance that's up to 5x faster than the previous-generation Drobos. This allows you to move large amounts of data in a fraction of the time it used to take.
  • Capacity and performance
    Data-Aware Tiering technology, usually reserved for business-class storage solutions, is also available in this desktop Drobo. It intelligently uses the high-performance flash in SSDs to accelerate performance of the storage array, allowing applications such as Adobe Premiere and Apple Aperture fast access to data. To keep capacity of the Drobo at a maximum, the Drobo accelerator bay accepts an industry-standard mSATA SSD, leaving all five 3.5" drives bays available for high-capacity HDDs.
Drobo Storage for Professionals Drobo 5D - hard drive array
Hard drive array
Total Array Capacity
0 GB
Max Supported Capacity
50 TB
USB 3.0, Thunderbolt 2
0 (installed) / 5 (max)
Supported Drives
SATA-600
Storage Controller
SATA (SATA 6Gb/s) - RAID 1, 5, 6, 5 hot spare
Hard Drive
0 HDD - hot-swap
Microsoft Windows 7 (32/64 bits) SP1, Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
AC 120/230 V - 50/60 Hz
15.03 cm x 26.23 cm x 18.54 cm
3.86 kg
1 year warranty
Hard drive array
Chassis
0
Supported Devices / Modules Qty
5
Supported Drives
SATA-600
Storage
0 GB
50 TB
HDD Array External Interface
Storage Capacity Details
Volume capacity 64 TB
Storage Controller
SATA
Interface Type
SATA 6Gb/s
Data Transfer Rate
600 MBps
RAID Level
RAID 1, RAID 5, RAID 6, RAID 5 hot spare
Hard Drive
HDD - hot-swap
0
Expansion Bays
5 (total) / 5 (free) x hot-swap - 3.5"
1 x USB 3.0 , 2 x Thunderbolt 2
1 x USB 3.0 cable - 2 m , 1 x Thunderbolt cable - 2 m
Software Included
Drivers & Utilities
External power adapter
15.03 cm
26.23 cm
18.54 cm
3.86 kg
Limited warranty - 1 year
Resources
The following resources are available for the Drobo 5D 5-bay Storage Array with Thunderbolt / USB 3.0
HD Size: 3.5"
Brand: Drobo
Price Range Ex VAT: 500 - 750
