Draytek VigorSwitch P-2261 PoE Gigabit Ethernet Switch
Quicklinx: 8PX7WS00 Mfr#: VSP2261
VigorSwitch P2261 is a L2+ managed PoE switch designed for small to medium sized businesses. It offers Power over Ethernet feature to ease the field deployment tasks. To cater for high bandwidth traffic, it is equipped with 20 Gigabit Ethernet ports for the LAN side, and 6 Dual SFP ports, 2 of which are for fiber and the other 4 can be used for either UTP (Ethernet cable) or SFP (fiber) connections, for the backbone side. It has security features to meet the needs of managing local and remote access to the network. Furthermore, it has VLAN capability to allow flexible network design, and QoS capability for flexible bandwidth control. It supports 802.3az energy saving standards, sFlow network monitoring, IPv6 and IPv4 and many other functions. With preset options for configuring network devices and plug and play features, this switch is truly an ideal solution for business grade network infrastructure.
  • PoE for efficient installation
    24-PoE ports allow power to be supplied to end devices, such as Wireless Access Points IP Phones and IP cams, directly through the existing LAN cables, eliminating costs for additional AC wiring and reducing Installation Cost. It frees your wireless AP deployment from restriction due to power outlet location. By supplying the power end-span, you can centralize power distribution and backup without the need to increase infrastructure.
  • Advanced network security
    Network security is a lifeline for modern day businesses, and is multi-faceted. To manage remote access, VigorSwitch P2261 supports SSH, SSL and SNMPv3 connection with encrypted packet content for each session. To prevent illegal access of data ports, it supports IP Source Guard which blocks illegal IP addresses for accessing specific ports or receiving data packets. To manage access to port-based network devices, it supports IEEE 802.1 X port security standard. And, to prevent illegal logins, it supports Access Control List (ACL) function, ensuring only authorized users can access designated network resources.
  • Virtual LAN
    WAN provides a way for businesses to assign network functions to different workgroups, branches, sections, employees or visitors, according to their operational requirements. VigorSwitch P2261 offers the Layer 2 Isolation feature (tag-based) WAN for the groups. You can also use network devices' MAC addresses for the WAN profiles (MAC-based VLAN).
  • Quality of Service for application Prioritization
    VigorSwitch P2261 is equipped with advanced QoS features to ensure that traffic for various applications is treated with the desired priorities. It offers classification types including: port based, 802.1p WAN priority based, IPv6/IPv4 precedence, type of services (ToS), DSCP based, Differv classification and remarking ACLs, Trusted QoS, etc. There are 8 priority levels based on 8 hardware queues, and these can be linked to time scheduling for upmost flexibility.
  • Easy configuration and connectivity
    With the increasing number of mobile devices joining PCs and servers in business environment, the configuration of network switches can be a source of frustration. VigorSwitch P2261 comes with preset options for network devices such as IP phone, IP camera, Wireless devices, etc. The web based configuration pages allow you to just select the well sorted options, such as security and network features (ACL, IP Source Guard, VLAN, QoS, etc. ) as required.
Draytek VigorSwitch P2261 - switch - 24 ports - Managed
Switch - 24 ports - L2+ - Managed
Subtype
Gigabit Ethernet
Ports
20 x 10/100/1000 + 4 x combo SFP + 2 x SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
185 W
Virtual interfaces (VLANs): 4096
MAC Address Table Size
8K entries
Jumbo Frame Support
9600 bytes
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH
Flow control, Layer 2 switching, auto-negotiation, trunking, VLAN support, IGMP snooping, port mirroring, DiffServ support, IPv6 support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, IPv4 support, LLDP support, DHCP relay, Generic VLAN Registration Protocol (GVRP)
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
44.2 cm x 30 cm x 4.4 cm
4.6 kg
1-year warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
185 W
8K entries
Jumbo Frame Support
9600 bytes
Routing Protocol
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
Built-in Devices
Led panel
Status Indicators
Port transmission speed, power, link/activity
24 x 1000Base-T RJ-45 PoE , 1 x console RJ-45 management , 6 x SFP (mini-GBIC)
Internal power supply
Power Provided
250 Watt
Rubber feet
1 x console cable
Rack Mounting Kit
Included
RoHS
Software Included
Drivers & Utilities
44.2 cm
30 cm
4.4 cm
4.6 kg
Limited warranty - 1 year
10 - 90% (non-condensing)
