DrayTek Vigor2925ac Dual-WAN 802.11ac
Quicklinx: BSB1WS00 Mfr#: V2925AC-K
  • IEEE 802.11n
Vigor 2925 series is an IPv6-ready dual Gigabit Ethernet WANs and dual USB WANs broadband security firewall router. It ensures the business continuity for IPv6 networks. Its two Gigabit Ethernet WAN ports can accept various high-speed Ethernet-based WAN links. With the multi-WAN accesses, Vigor 2925 series router provides flexible and reliable broadband connectivity for small business office. The VPN backup and VPN load balancing assures business continuity via multi-WAN connection to the Internet.
  • Dual Gigabit Ethernet WAN ports for failover and load-balancing
    The Gigabit Ethernet WAN ports cater for any type of Internet access, including FTTx, xDSL and Cable fitting your local infrastructure. You can then use both WAN 1 and WAN 2 for failover, ensuring that you will have an access to the Internet even if one of the WAN fails.
  • Two USB 2.0 ports for 3.5G/4G LTE USB mobiles, FTP drive and network printer
    The two USB ports can be used for the connection of 3G/4G LTE USB mobiles mobile, FTP drive and network printers. A 3.5G/4G USB mobile connected to one of the 2 USB ports can be used as a second WAN.
  • DrayTek IPv6 solutions
    Your business operation can be successfully migrated to the era of IPv6.
  • Secured networking
    The firewall allows setting of call and data filters and DoS/DDoS prevention. The object-based design used in SPI firewall allows users to set firewall policy with ease. The object-based firewall is flexible and allows your network be safe.
  • Multi-subnets
    With the 5-port Gigabit switch on the LAN side, the Gigabit LAN switch provides high-speed connectivity for high-speed local data transfer of any server or local PCs. The tagged VLANs can mark data with a VLAN identifier.
  • Comprehensive VPN
    For remote teleworkers and inter-office links, Vigor 2925 series provide simultaneous VPN tunnels for secure data exchange and communication. With a dedicated VPN coprocessor, the hardware encryption of AES/DES/3DES and hardware key hash of SHA-1/MD5 are seamlessly handled, thus maintaining advanced router performance.
  • Centralized management
    With F/W 3.7.4, the embedded central VPN management will let network administrator register remote routers and run concurrent remote management over remote routers.
  • Central AP management
    APM provides a 3-step installation for wireless clients to be able to enjoy surfing the Internet. Moreover, through the unified user interface of routers, the status of APs is clear at the first sight.
  • Flexible network management
    Vigor2925 series routers support comprehensive network management functions. For example, you can set username/password and directory/file access privilege for individual users as required.
Draytek Vigor 2925ac - wireless router - Wi-Fi 5 - desktop
Wireless router - 5-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
UPnP sessions: 30 , VPN tunnels: 50 , SSL VPN tunnels: 16
Network / Transport Protocol
PPTP, L2TP, NTP, IPSec, PPPoE, FTP, DHCP, DNS
Routing Protocol
RIP-2, static IP routing, policy-based routing (PBR)
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
DMZ port, DHCP support, VPN support, load balancing, IGMP snooping, Syslog support, DoS attack prevention, content filtering, dynamic DNS server, DiffServ support, manageable, E-mail alert, print server, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, Access Point operational mode, PSTN Lifeline, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Trivial File Transfer Protocol (TFTP) support, Quality of Service (QoS), dual WAN connection, Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Samba support, Multiple SSID support, hidden SSID, DNS proxy, bandwidth control, IPv4 support, DHCP relay, Stateful Packet Inspection Firewall (SPIF), 3G/4G USB Dongle Support, anti-spoofing protection, DHCP client, Management Information Base (MIB), tagged VLAN, IM/P2P filter, DNS caching, Content Security Management (CSM), Type of Service (ToS), DiffServ Code Point (DSCP) support
IEEE 802.1Q, IEEE 802.1p, IEEE 802.1x, IEEE 802.11e, Wi-Fi Protected Setup, UPnP, IEEE 802.11ac
24.1 cm x 16.5 cm x 4.4 cm
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID)
LAN: 5 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
External power adapter
24 Watt
24.1 cm
16.5 cm
4.4 cm
45 °C
10 - 90% (non-condensing)
