Product
DrayTek Vigor P2280 PoE L2 Managed Gigabit Switch
Quicklinx: DCSNWS00 Mfr#: VSP2280-K
20 in stock
£354.44 ex VAT
£425.32 inc VAT
VigorSwitch P2280 offers features that help to build a secure business network, such as VLAN, Port Isolation, Storm Control, and DoS Defense. While allowing visitors to connect to the network for Internet access, these features help to block the visitors' access to business network resources and protect the network from being exhausted by malicious traffic.
All the 24 Ethernet ports of VigorSwitch P2280 are compatible with 802.3at and 802.3af standard, provide up to 30W per port to network devices such as wireless access points, IP phones, and IP surveillance. This reduces the need for power cables and adapters, which lowers the cost of installation, as well as offers the flexibility to install those devices, not being limited by where the power outlets are.
  • LAN management
  • 24 PoE+ capable ports
  • Voice VLAN to improve call quality
    The Voice VLAN feature allows VigorSwitch P2280 to automatically identify the traffic from a VoIP device and assign their source port to a separate VLAN. This allows the switch to efficiently give VoIP traffic a higher priority over others, thus to ensure the best call quality.
  • Speed up the network by link aggregation
    If cascading more switches are required, link aggregation will provide the network higher throughput and link redundancy. VigorSwitch P2280 supports link aggregation by both static configuration and LACP (Link Aggregation Control Protocol), up to 8 Link Aggregation Group can be set up on VigorSwitch P2280, and each of the group can have up to 8 port members.
  • Easy setup & monitoring
    VigorSwitch P2280 has adopted a brand-new interface design which will make configuration and management much easier. The new dashboard shows the status of the system and each of LAN ports at a glance. Furthermore, the responsive web design allows Network Administrator to monitor the switch effortlessly via all kinds of devices.
Draytek VigorSwitch P2280 - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 4 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
340 W
Virtual interfaces (VLANs): 4096
MAC Address Table Size
8K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3, MLDv2, MLD
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, TR-069
Flow control, Layer 2 switching, auto-negotiation, VLAN support, IGMP snooping, Syslog support, port mirroring, Weighted Round Robin (WRR) queuing, IPv6 support, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, event log, DHCP snooping, Quality of Service (QoS), IP Precedence, SSH support, IPv4 support, LACP support, LLDP support, Link Aggregation Control Protocol (LACP), port based access control, Strict Priority Queuing (SPQ), port isolation, Class of Service (CoS), Generic VLAN Registration Protocol (GVRP), Denial of Service (DoS), DiffServ Code Point (DSCP) support, Storm Control, cable test, dual image support, Voice VLAN, Energy-Efficient Ethernet (EEE), Weighted Round Robin (WRR), port-based VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
AC 230V
44.1 cm x 27 cm x 4.5 cm
4.35 kg
United Kingdom
2 years warranty
Enclosure Type
Desktop, rack-mountable, wall-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
340 W
8K entries
Jumbo Frame Support
9KB
Routing Protocol
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
Status Indicators
Power, PoE, link/activity
24 x 1000Base-T RJ-45 PoE+ - 30 W , 4 x Gigabit LAN SFP , 4 x 1000Base-T RJ-45 , 1 x console RJ-45
Internal power supply
AC 230V
453.3 Watt
Rack Mounting Kit
Included
RoHS
United Kingdom
44.1 cm
27 cm
4.5 cm
4.35 kg
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Brand: DrayTek
Price Range Ex VAT: 300 - 500
