DrayTek Vigor P1092 PoE Web Smart Gigabit Switch
Quicklinx: DCSLWS00 Mfr#: VSP1092-K
Type: Gigabit Ethernet
Ports: 8
Managed: Yes
POE: PoE+
10 in stock
£134.44 ex VAT
£161.32 inc VAT
The VigorSwitch P1092 is ideal for SOHO and small business with the high-performance capability. To cater for high bandwidth traffic, it is equipped with Gigabit Ethernet ports for the LAN side, and SFP ports for the backbone side. VigorSwitch P1092 is equipped with extensive facilities for maximizing your LAN performance, VLAN capability to allow flexible network design, and QoS capability for flexible bandwidth control.
  • LAN management
    VigorSwitch P1092 offers features that help to build a secure business network. While allowing visitors to connect to the network for Internet access, these features help to block the visitors' access to business network resources and protect the network from being exhausted by malicious traffic.
  • Speed up the network by link aggregation
    If cascading more switches are required, link aggregation will provide the network higher throughput and link redundancy.
Draytek VigorSwitch P1092 - switch - 8 ports - smart - rack-mountable
Switch - 8 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
110 W
Performance
Switching capacity: 20 Gbps , Forwarding rate: 14.88 Mpps
VLANs supported: 8 , Link aggregation groups: 2 , QoS queues: 4 , Links per group: 2
MAC Address Table Size
4K entries
Jumbo Frame Support
9KB
Remote Management Protocol
HTTP
Flow control, DHCP support, auto-negotiation, port mirroring, firmware upgradable, Weighted Fair Queuing (WFQ), Quality of Service (QoS), reset button, bandwidth control, IPv4 support, Link Aggregation Control Protocol (LACP), Class of Service (CoS), tagged VLAN, VoIP support, Storm Control, ingress rate limiting, Energy-Efficient Ethernet (EEE), port-based VLAN, egress rate limiting, port trunking
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
26.5 cm x 18.4 cm x 4.4 cm
1.68 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
110 W
Performance
4K entries
Jumbo Frame Support
9KB
HTTP
Built-in Devices
Led panel
Status Indicators
Power, alert, system, PoE, link/activity
8 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x Gigabit LAN SFP
Internal power supply
Rubber feet
Rack Mounting Kit
Included
RoHS
26.5 cm
18.4 cm
4.4 cm
1.68 kg
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 8
Managed: Yes
POE: PoE+
Brand: DrayTek
Price Range Ex VAT: 100 - 150
