DrayTek Vigor 3910 Multi-WAN router
Quicklinx: FN12WS00 Mfr#: V3910-K
£579.57 ex VAT
£695.48 inc VAT
The DrayTek Vigor 3910 is a multi-WAN router and an ideal VPN concentrator, delivering high performance to meet the current and future bandwidth demands of complex networks. The Vigor 3910 combines performance, capacity and flexibility, with ease of use and a comprehensive feature set.
  • Powerful enterprise Internet gateway
    Featuring a quad-core processor, the Vigor 3910 readily meets the needs of demanding networks, with over 9Gb/s NAT throughput delivered through its 10GbE and 2.5GbE ports.
  • High-performance VPN concentrator
    Protect inter-office communication with securely encrypted Virtual Private Network tunnels, maintaining 3 Gb/s IPsec throughput and supporting 500 simultaneous VPN links.
  • Flexible WAN architecture
    Spread the load across up to 8 WAN links with Load Balancing. Policy-based Routing enables intelligent and flexible failover, for reliable and resilient connectivity.
  • High availability
    Provide hardware redundancy to mission critical applications with the installation of a second Vigor 3910. The backup autonomously resumes connections in the event of hardware failover.
  • Manage multiple networks
    Create up to 50 VLANs, port-based or tag-based. Each fully configurable for NAT or Routing, sharing resources between networks or isolated from each other.
Draytek Vigor 3910 - router - rack-mountable
Router
Enclosure Type
Rack-mountable - 1U
WAN Ports Qty
8
Ethernet, Fast Ethernet, Gigabit Ethernet, PPP, 10 Gigabit Ethernet, 2.5 Gigabit Ethernet
Performance
NAT throughput: 9 Gbps , VPN throughput (IPSec): 3.3 Gbps , VPN throughput (SSL): 1 Gbps
Concurrent VPN tunnels: 500 , Virtual interfaces (VLANs): 50 , NAT sessions: 150000 , Dynamic IP pool: 4093 , Concurrent SSL VPN tunnels: 200
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, FTP, DHCP, DNS, Bonjour, SMB, DDNS, DHCPv6, RTSP, IPv4, IPv6
Routing Protocol
RIP-1, RIP-2, BGP, IGMP, OSPFv2, static IP routing, GRE, static IPv4 routing, static IPv6 routing, policy-based routing (PBR), RIPng
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, SSH, TR-069
VoIP Protocols
H.323, SIP
Firewall protection, NAT support, VPN support, load balancing, VLAN support, Syslog support, DoS attack prevention, content filtering, ALG support, port mirroring, E-mail alert, IPv6 support, High Availability, URL filtering, IP address filtering, firmware upgradable, file sharing, Access Control List (ACL) support, Quality of Service (QoS), Data prioritization (Qos) for VoIP applications, IPSec NAT-Traversal (NAT-T), DHCP server, SMS alert, reset button, IPv4 support, DNS server, port triggering, anti-spoofing protection, IP-MAC binding, IGMP proxy, Type of Service (ToS), DiffServ Code Point (DSCP) support, VPN concentrator, failover protection, Web Filtering, Application Level Gateways (ALGs), DMZ support, VLAN Tagging, port-based VLAN, Bandwidth Limiter, DynDNS, Brute Force Protection
IEEE 802.1Q, IEEE 802.1p, X.509, UPnP
AC 230V
44.3 cm x 28.5 cm x 4.5 cm
3.23 kg
United Kingdom, Ireland
Router
Enclosure Type
Rack-mountable - 1U
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, SSL, SHA-1, IKEv2, 256-bit SHA
Authentication Method
RADIUS, X.509 certificates, TACACS+, LDAP, internal user database, XAUTH authentication
1.2 GHz
Built-in Devices
Led panel
IP Telephony
VoIP Protocols
H.323, SIP
WAN / LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 2 x 2.5GBase-T - RJ-45 , WAN / LAN: 2 x 10Gb Ethernet / 1Gb Ethernet - SFP+ , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , Management: 1 x RS-232 - RJ-45
Internal power supply
AC 230V
35 Watt
1 x network cable , 1 x serial cable
Rack Mounting Kit
Included
OS Provided
DrayOS
44.3 cm
28.5 cm
4.5 cm
3.23 kg
Limited warranty - 2 years - carry-in
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: 10 Gigabit Ethernet
Standards: 2.5 Gigabit Ethernet
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: PPP
Brand: DrayTek
Price Range Ex VAT: 500 - 750
