DrayTek Vigor 2862 Series ADSL/VDSL Router with 802.11n 3G/4G/LTE
Quicklinx: D6B0WS00 Mfr#: V2862LN-K
Type: Wireless router
Connection Type: ADSL or VDSL
Standards: Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b + 2 more
  • IEEE 802.11n
More than 50 in stock
£351.61 ex VAT
£421.93 inc VAT
The embedded 4G/LTE connectivity provides a self-contained solution as opposed to having to add external/USB modems to your router. A standard SIM slot on the back of the router is secured with a cover to prevent accidental removal (you can leave the cover off if you need easy access). As well as connectivity to the 4G (LTE) networks, the Vigor 2862L series provides backward compatibility to 3G networks for areas or networks where 4G isn't available. Full function MS message operation also provides additional functionality and control.
Draytek Vigor 2862LN - wireless router - DSL/WWAN - 802.11b/g/n - desktop
Wireless router - DSL modem / wireless cellular modem - 5-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL2, ADSL2+, READSL, VDSL2
Cellular Protocol
GSM, GPRS, UMTS, HSDPA, HSPA+, LTE
WAN Ports Qty
2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Performance
Firewall throughput: 400 Mbps , VPN throughput (IPSec): 60 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, DHCP
Routing Protocol
RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI, TR-069, TR-104
Firewall protection, NAT support, VPN support, load balancing, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), RADIUS support, DHCP server, Multiple SSID support, hidden SSID, Bandwidth-On-Demand (BOD), DHCP relay, 3G/4G USB Dongle Support, DHCP client, Management Information Base (MIB), 4T4R MIMO technology, tagged VLAN, DNS caching, Content Security Management (CSM), Type of Service (ToS), DiffServ Code Point (DSCP) support, beamforming technology, Airtime Fairness, congestion avoidance (based on IP precedence/DSCP-based WRED)
IEEE 802.1Q, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11e, IEEE 802.11n
AC 230V
24.096 cm x 16.507 cm x 4.396 cm
Wireless router - 5-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
Authentication Method
RADIUS, X.509 certificates, Radio Service Set ID (SSID)
Status Indicators
Power, WAN, wireless, link/activity, USB, VPN, DSL
Communications
Cellular Protocol
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.997.1, ITU G.992.3 (G.DMT.bis), ITU G.992.3 Annex A, ITU G.992.3 Annex L, ITU G.992.5 Annex M, ITU G.993.1, ITU G.993.2, ITU G.992.3 Annex M, ITU G.992.5 Annex A, ITU G.992.5 Annex L
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Antenna: 2 x SMA
Expansion Slots
1 (total) / 1 (free) x SIM
Aerial
Aerial
External detachable
Antenna Qty
4
External power adapter
AC 230V
18 Watt
Rack Mounting Kit
Optional
24.096 cm
16.507 cm
4.396 cm
45 °C
10 - 90% (non-condensing)
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Brand: DrayTek
Price Range Ex VAT: 300 - 500
