Vigor 2860 series security firewall router has built-in VDSL2/ADSL2+ modem, plus a second Ethernet WAN port for cable or satellite broadband, and 2 USB ports for 3G/4G mobile broadband access. With the multi-WAN accesses, Vigor 2860 router supports bandwidth management functions such as fail-over and load balancing, making them ideal solutions for reliable and flexible broadband connectivity for small to large enterprises.
Fail-over and Load Balancing with a second Gigabit Ethernet WAN
The Gigabit Ethernet WAN port caters for any type of Internet access, including ADSL, Cable or Satellite broadband. You can then use both WAN 1 and WAN 2 for Fail-over, ensuring that you will always have an access to the Internet even if one of the WAN fails, or for Load Balancing so the 2 WANs share Internet traffic requirements of your organization. -
Comprehensive VPN
For remote teleworkers and inter-office links, Vigor2860 series provide up to 32 simultaneous VPN tunnels (such as IPSec/PPTP/L2TP protocols) for secure data exchange and communication. With a dedicated VPN co-processor, the hardware encryption of AES/DES/3DES and hardware key hash of SHA-1/MD5 are seamlessly handled, thus maintaining maximum router performance. Teleworkers can be authenticated directly with your LDAP server if preferred. The Vigor2860 series are equipped with physical DSL port and Gigabit Ethernet port for WAN load-balancing and backup. The VPN trunking (VPN load-balancing and VPN backup) are hence implemented on Vigor2860 series. With VPN trunking, you can create multiple WAN connections to a remote site in order to increase bandwidth. The VPN trunking also can allow you to have failover (backup) of VPN route through a secondary WAN connection. With SSL VPN, Vigor2860 series let teleworkers have convenient and simple remote access to central site VPN. The teleworkers do not need to install any VPN software manually. From regular web browser, you can establish VPN connection back to your main office even in a guest network or web cafe. The SSL technology is same as the encryption that you use for secure web sites such as your online bank. The SSL VPNs can be operated in either full tunnel mode or Proxy mode. After F/W 3.7.3, the Vigor2860 series allows up to 16 simultaneous incoming users. -
Centralized Management
With F/W 3.7.3, the embedded Central VPN Management (CVM) will let network administrator register up to 16 remote routers but run concurrent remote management over 8 remote routers. -
AP Management
APM provides the 3-step installation, plug-plug-press, and then wireless clients are able to enjoy surfing internet. Moreover, through the unified user interface of Draytek routers, the status of APs is clear at the first sight. -
Multi-subnet
With the 6-port Gigabit switch on the LAN side provides extremely high speed connectivity for the highest speed local data transfer of any server or local PCs. The tagged VLANs (802.1q) can mark data with a VLAN identifier. This identifier can be carried through an onward Ethernet switch to specific ports. The specific VLAN clients can also pick up this identifier as it is just passed to the LAN. You can set the priorities for LAN-side QoS. You can assign each of VLANs to each of the different IP subnets that the router may also be operating, to provide even more isolation. The said functionality is tag-based Multi-subnet.
- Draytek Vigor 2860LN - wireless router - DSL/WWAN - Wi-Fi - desktop
- Wireless router - DSL modem / wireless cellular modem - 6-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2, ADSL2+, READSL, VDSL2
- Mobile Communication Protocol
- GPRS, EDGE, WCDMA, LTE
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Capacity
- VPN tunnels: 32 , SSL VPN tunnels: 16 , UPnP sessions: 30
- PPTP, L2TP, NTP, PPPoE, PPPoA, FTP, DHCP
- Routing Protocol
- RIP-2, IGMPv2, static IP routing, IGMPv3
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, TFTP, SSH, CLI, TR-069
- Firewall protection, DMZ port, VPN support, trunking, load balancing, VLAN support, IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, E-mail alert, MAC address filtering, IPv6 support, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Multiple SSID support, hidden SSID, DNS proxy, reset button, bandwidth control, Wireless Client Mode, DHCP relay, anti-spoofing protection, DHCP client, tagged VLAN, Diagnostic Function, DNS caching, IGMP proxy, Type of Service (ToS), DiffServ Code Point (DSCP) support
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.3ah, IEEE 802.11e, IEEE 802.11n, UPnP
- 24.1 cm x 16.5 cm x 4.4 cm
- Localisation
- United Kingdom
- Wireless router - 6-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, MD5, MPPE, AES, 128-bit WEP, 64-bit WEP, IKE, SHA-1, WPA, WPA2
- Authentication Method
- Secure Shell (SSH), RADIUS, X.509 certificates, Radio Service Set ID (SSID)
- Built-in Devices
- Led panel
- Status Indicators
- Power, WLAN, WAN, link/activity, USB, DSL
Communications
- Protocols & Specifications
- ITU G.992.1 (G.DMT), ITU G.992.3 (G.DMT.bis), ITU G.992.1 (G.DMT) Annex A, ITU G.992.3 Annex A, ITU G.993.2, ITU G.992.5 Annex A
- Max Transfer Rate
- 150 Mbps
- LAN: 6 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter
- 24 Watt
- Rack Mounting Kit
- Optional
- Localisation
- United Kingdom
- 24.1 cm
- 16.5 cm
- 4.4 cm
- 0 °C
- 45 °C
- 10 - 90% (non-condensing)
