Product
DrayTek Vigor 2832 ADSL Router/Firewall
Quicklinx: C714WS00 Mfr#: V2832-K
Type: Router
Standards: ATM, Ethernet, Fast Ethernet, Gigabit Ethernet
40 in stock
£135.48 ex VAT
£162.57 inc VAT
The Vigor 2832 series (including the Vigor 2832n) is our new router/firewall for ADSL lines. Alternative WAN ports can insead provide connectivity to Ethenet feeds, secondary xDSL modems or a 3G/4G cellular service using a supported USB adaptor. This latest router series includes support for professional features such as VLAN tagging, Gigabit Ethernet built-in WiFi ('n' models).
Packed with professional-level features, the Vigor 2832 series is compatible with all UK variants of ADSL (including ADSL2+ and Annex M) and the Vigor 2832 can also be used for cable-modem, leased line and EFM applications using its Gigabit Ethernet WAN port.
  • Robust and comprehensive firewall
    Security is always taken seriously with DrayTek routers. The firewall protects against attacks including DoS (Denial of Service) attacks, IP-based attacks and access by unauthorized remote systems. Wireless, Ethernet and VPN are also protected by various protection systems. The DrayTek object-based firewall allows even more setup flexibility than ever, enabling you to create combinations of users, rules and restrictions to suit multi-departmental organizations. The Vigor 2832 also allows selective direction firewall rules of LAN to WAN, WAN to LAN or LAN to VPN. In addition, QoS (Quality of Service Assurance) can be selectively applied to specific users within your NAT subnet according to source or destination IP address.
  • Web content filtering
    The content control features of the Vigor 2832 allows you to set restrictions on web site access, blocking download of certain file or data types, blocking specific web sites with whitelists or blacklists, blocking IM/P2P applications or other potentially harmful or wasteful content. Restrictions can be per user, per PC or universal.
  • WAN load balancing & backup
    The Vigor 2832 features three methods of WAN connectivity - ADSL, Ethernet (Gigabit) and two USB ports for connection of a 3G/4G modem. The Ethernet port can connect to a second ADSL or VDSL modem (e.g. Vigor 120 or Vigor 130), a cable modem or any other Ethernet-based Internet feed. The multiple WAN interfaces can be used either for WAN-Backup or load balancing.
  • Linking remote offices, HQ, teleworkers and mobile staff
    A feature central to DrayTek routers is the VPN (Virtual Private Networking) features. A VPN enables you to link two remote offices, branch offices back to HQ or home-based/mobile teleworkers back to your office. Once connected, they have access to your office/remote resources through a secure encrypted tunnel allowing remote desktop, file sharing and seamless access to other resources and devices.
Draytek Vigor 2832 - router - DSL modem - desktop
Router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop - 1U
Digital Signaling Protocol
ADSL2, ADSL2+
WAN Ports Qty
2
Ethernet, ATM, Fast Ethernet, Gigabit Ethernet
Performance
Firewall throughput: 300 Mbps , VPN throughput (IPSec): 50 Mbps
Concurrent VPN tunnels: 32 , SSL VPN tunnels: 10
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA
Routing Protocol
RIP-2, static IP routing
Remote Management Protocol
Telnet, SNMP 3, HTTP, HTTPS, SSH, CLI, TR-069
Firewall protection, DMZ port, NAT support, VPN support, load balancing, LDAP support, VLAN support, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, dynamic DNS server, DiffServ support, MAC address filtering, IPv6 support, VPN passthrough, firmware upgradable, DDos attack prevention, Quality of Service (QoS), Dead Peer Detection (DPD), IPSec NAT-Traversal (NAT-T), DHCP server, SMS alert, Bandwidth-On-Demand (BOD), IPv4 support, DHCP relay, anti-spoofing protection, DHCP client, static routing, tagged VLAN, Type of Service (ToS), keyword filtering, failover protection
IEEE 802.1Q, ANSI T1.413, IEEE 802.1x, IEEE 801.1p, UPnP
AC 230V
United Kingdom
2 years warranty
Router - 4-port switch (integrated)
Enclosure Type
Desktop - 1U
Wired
Performance
Routing Protocol
Encryption Algorithm
DES, Triple DES, MD5, IKE, SHA-1, 128-bit AES, 192-bit AES, 256-bit AES, 256-bit SHA
Authentication Method
RADIUS, LDAP
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 (G.DMT.bis), ITU G.992.5
USB 2.0: 2 x 4 pin USB Type A , WAN: 1 x ADSL2+ - RJ-11 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
AC 230V
18 Watt
Rack Mounting Kit
Optional
United Kingdom
45 °C
10 - 90% (non-condensing)
Type: Router
Standards: ATM
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Brand: DrayTek
Price Range Ex VAT: 100 - 150
