Product
Brand
Draytek Vigor 2760Vn ADSL or VDSL with WiFi 802.11n VoIP Router
Quicklinx: 8PMRWS00 Mfr#: V2760VN-K
  • IEEE 802.11n
Now with "DrayOS Firmware!"
Vigor 2760 provides connectivity to your PCs or other Internet-connected devices (laptops, tablets, games consoles, smartphones) via its built-in Gigabit ports, or using Wireless LAN (on 'n' models). The firewall helps protect your network from external threats, as well as the Vigor2760's built-in content filtering which gives you control over what and when your local users can access or download. For Wireless LAN usage, the Vigor2760n version supports multiple security methods, including strong encryption but also hardware-specific authorization and selectable client isolation (from each other).
The Vigor 2760 supports all variants of mass-market DSL technology available, so if you have ADSL today it will work with that, but when VDSL (FTTC) comes to your area later, you're ready, already. VDSL is available from BT under their 'Infinity ' service, currently providing downstream speeds of up to 160Mb/s (depending on local service). Other ISPs are also starting to introduce VDSL across the country so coverage continues to increase. You can also use 3G/4G networks.
Draytek Vigor 2760Vn - wireless router - DSL modem - 802.11b/g/n - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, VDSL, ADSL2+, VDSL2
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
VPN tunnels: 2 , UPnP sessions: 30 , NAT sessions: 20000
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE, PPPoA, FTP, DHCP, DDNS
Routing Protocol
IGMPv2, IGMP, MPOA
Remote Management Protocol
Telnet, HTTP, HTTPS, SSH
VoIP Protocols
SIP, RTCP, RTP
Telephony Interfaces
2 phone (FXS), 1 line (FXO)
Flow control, firewall protection, DHCP support, NAT support, ARP support, VLAN support, wake on LAN (WOL), IGMP snooping, Syslog support, Stateful Packet Inspection (SPI), DoS attack prevention, content filtering, packet filtering, DiffServ support, MAC address filtering, IPv6 support, Wireless Distribution System (WDS) support, URL filtering, IP address filtering, firmware upgradable, DDos attack prevention, Wi-Fi Multimedia (WMM) support, Dead Peer Detection (DPD), Wi-Fi Protected Setup (WPS), WAN failover, DHCP server, Samba support, Multiple SSID support, hidden SSID, DNS proxy, 2T2R MIMO technology, IPv4 support, 3G/4G USB Dongle Support, anti-spoofing protection, Traffic Control, IP-MAC binding, policy based access control, DNS caching, IGMP proxy, Content Security Management (CSM)
X.509, UPnP
AC 120/230 V
12.5 cm x 18.2 cm x 4 cm
2 years warranty
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Routing Protocol
IGMPv2, IGMP, MPOA
Encryption Algorithm
DES, Triple DES, MD5, MPPE, AES, IKE, SHA-1, WPA, WPA2, PKI, WEP
X.509, UPnP
Flash Memory
40 MB
Built-in Devices
Led panel
Line Properties
Framing Format
ANSI T1.413
Communications
DSL modem
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.997.1, ITU G.992.5, ITU G.993.1, ITU G.993.2
IP Telephony
VoIP Protocols
SIP, RTCP, RTP
Voice Codecs
G.711, G.723.1, G.729a, G.711u, G.711a, G.726, T.38, G.729b
IP Telephony Features
Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (G.168), call forwarding, call waiting, call hold, call transfer, message waiting, DTMF generation/detection, Calling Line Identification Restriction (CLIR)
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x VDSL2 / ADSL2+ - RJ-11 , Phone line: 2 x FXS - RJ-11 , Phone line: 1 x FXO - RJ-11 , Antenna: 2 x , USB 2.0: 2 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
2
External power adapter
AC 120/230 V
16.3 Watt
12.5 cm
18.2 cm
4 cm
10 - 90% (non-condensing)
