DrayTek ANT-1207 is a High-gain Omni-directional indoor antenna to extend the wireless range of your existing base station, such as Wireless Access Point and Wireless Router, in 2.4GHz and 5GHz.
The DrayTek Antenna series are designed to connect with most wireless devices that use detachable antenna with R-SMA connector. Simply unscrew the existing antenna on your device and connect on DrayTek high gain antenna series and enjoy the benefits of wireless network.
- Draytek ANT-1207 - antenna
- Product Type
- Antenna
- Intended For
- Wi-Fi
- Aerial Placing / Mounting
- Indoor
- Compatibility
- 802.11 a/b/g/n/ac
- Frequency Range
- 2.4 - 2.5 GHz, 5.15 - 5.85 GHz
- Gain
- 7 dBi (for 5 GHz), 5 dBi (for 2.4 GHz)
- Directivity
- Omni-directional
- 1-year warranty
- Product Type
- Antenna
Aerial
- Intended For
- Wi-Fi
- Indoor
- Compatibility
- 802.11 a/b/g/n/ac
- Frequency Range
- Gain
- Directivity
- Omni-directional
- Voltage Standing Wave Ratio (VSWR)
- 2.0:1 (for 2400 MHz), 3.0:1 (for 5000 MHz)
- Horizontal Beamwidth
- 360°
- Vertical Beamwidth
- 80°
- Impedance
- 50 Ohm
Cabling & Wiring
- Connector Provided
- 1 x RP-SMA male
- MIMO technology
- Limited warranty - 1 year
