DrayTek 7dB Dual-Band Omni Aerial - White
Quicklinx: BZ2DWS00 Mfr#: ANT-1207
£13.75 ex VAT
£16.50 inc VAT
DrayTek ANT-1207 is a High-gain Omni-directional indoor antenna to extend the wireless range of your existing base station, such as Wireless Access Point and Wireless Router, in 2.4GHz and 5GHz.
The DrayTek Antenna series are designed to connect with most wireless devices that use detachable antenna with R-SMA connector. Simply unscrew the existing antenna on your device and connect on DrayTek high gain antenna series and enjoy the benefits of wireless network.
Draytek ANT-1207 - antenna
Antenna
Intended For
Wi-Fi
Aerial Placing / Mounting
Indoor
Compatibility
802.11 a/b/g/n/ac
Frequency Range
2.4 - 2.5 GHz, 5.15 - 5.85 GHz
Gain
7 dBi (for 5 GHz), 5 dBi (for 2.4 GHz)
Directivity
Omni-directional
1-year warranty
Antenna
Aerial
Intended For
Wi-Fi
Indoor
Compatibility
802.11 a/b/g/n/ac
Frequency Range
Gain
Directivity
Omni-directional
Voltage Standing Wave Ratio (VSWR)
2.0:1 (for 2400 MHz), 3.0:1 (for 5000 MHz)
Horizontal Beamwidth
360°
Vertical Beamwidth
80°
Impedance
50 Ohm
Cabling & Wiring
Connector Provided
1 x RP-SMA male
MIMO technology
Limited warranty - 1 year
Brand: DrayTek
Price Range Ex VAT: 0 - 50
