- DJI Phantom 4 Pro - quadcopter
- Product Type
- Quadcopter
- Included Items
- Micro-USB cable, battery charger, power cable, carrying case, remote controller, 4 propellers, 16 GB MicroSD card, gimbal clamp, intelligent flight battery, USB OTG cable
- Category
- Vehicles - drones
- Compatibility
- iPhone, iPad, Android phone
- Camera
- Included - 20 Megapixel
- Interface
- USB
- 1.388 kg
- Product Type
- Quadcopter
- Included Items
- Category
- Vehicles - drones
- Compatibility
- Size
- 350 mm
- Remote Control
- Yes - 5.8 GHz - max operating distance: 7 km
- Power Source
- Battery
- Supported Flash Memory Cards
- microSDHC UHS-I Memory Card, microSDXC UHS Class 3 Memory Card, microSDXC UHS-I Memory Card, microSDHC UHS Class 3 Memory Card, microSD Class 10 up to 128 GB
- Obstacle avoidance system
RC Vehicle
- Take-Off Weight
- 1388 g
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.3 metres
- Max Angular Velocity
- 250° per second
- Max Tilt Angle
- 42°
- Interface
- USB
- Wi-Fi Bands
- 2.4 GHz, 5 GHz
Gimbal
- Control Accuracy
- 0.02°
- Control Angle Range
- -90 to 30°
- Max Speed
- +/- 90° per second
Digital Camera
- Sensor Resolution
- 20 Megapixel
- Capture Formats
- H.264, MP4, MOV, H.265
- Video Recorder Resolutions
- 1280 x 720 (720p), 1920 x 1080 (1080p), 3840 x 2160 (2160p), 4096 x 2160, 2720 x 1530
- Frame Rate
- 30 frames per second
- Still Image Formats
- JPEG, RAW, DNG
- Supported Battery Configurations
- 4S
- Technology
- Lithium polymer
- Voltage
- 15.2 V
- Capacity
- 5870 mAh
- Run Time
- Up to 30 min
- Controller Battery
- 1 x 2S
- 1.388 kg
- 0 °C
- 40 °C
