DJI Phantom 4 Battery Charging Hub
Quicklinx: CYM9WS00 Mfr#: CP.PT.000343
The Phantom 4 Battery Charging Hub is designed for use with the Phantom 4 Intelligent Flight Battery. When used with the Phantom 4 Battery Charger, it can charge up to three Intelligent Flight Batteries. The Intelligent Flight Batteries will be charged in sequence according to their power levels, from high to low. Storage Mode allows the Charging Hub to keep the Phantom 4 Intelligent Flight Battery at a 50% charge, which is ideal for storage.
DJI Battery Charging Hub battery charger
Battery charger
162 g
AC 100-240 V (50/60 Hz)
Voltage Provided
17.5 V
Supported Battery
3
Phantom 4
Battery charger
Drone
162 g
Voltage Provided
17.5 V
Supported Battery
Max Supported Qty
3
FCC
DJI Phantom 4
