How do you capture moments worth keeping? As the smallest 3-axis stabilized handheld camera DJI has ever designed, the compact and intelligent Osmo Pocket turns any moment into a cinematic memory. In just seconds, Osmo Pocket lets you share your life anywhere, anytime.
Incredibly small, truly smooth
Osmo Pocket uses DJI's smallest 3-axis mechanical handheld gimbal. In real time, it precisely adjusts for your movements, turning your handheld video of a golden sunset or your child's first steps into a movie-like scene. -
A powerful tool for limitless imagination
Osmo Pocket transforms all your life's moments into wonderful images. It snaps photos in stunning detail, thanks to a 1/2.3-inch sensor, 80° FOV, and f/2.0 aperture. It can also shoot 4K/60fps video at 100 Mbps and photos at 12 MP with a pixel size of 1.55 µm for footage worth sharing every time. -
Noiseless cooling system
For perfectly quiet performance, Osmo Pocket takes advantage of a fanless, passive cooling solution that dissipates heat evenly, ensuring longevity and consistent performance. -
Single-handed design
A sandstone handle is non-slip and sweat-proof, offering a comfortable grip. The built-in touchscreen and buttons provide a quick, single-handed user experience, letting you choose modes and adjust settings in a few swipes and taps. -
Universal Port
Osmo Pocket includes a Universal Port - the door to further creativity. This multifunctional expansion interface connects Osmo Pocket to your smartphone, as well as an ever-growing suite of accessories that sets you free to film in any way. -
Designed with intelligence in mind
Osmo Pocket doesn't just let you shoot smooth, cinematic footage. With access to several intelligent functions like ActiveTrack, Motionlapse, and 3x3 Panorama, Osmo Pocket unleashes your creativity with impressive effects that are impossible with smartphones.
- DJI Osmo Pocket - action camera
- Product Type
- Action camera - 4K
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Lens System
- Wide-angle lens f/2.0
- Image Stabiliser
- Optical (3-axis gimbal)
- Display
- LCD display - 1"
- Supported Battery
- (included)
- 12.19 cm x 2.86 cm x 3.444 cm
- 116 g
- Product Type
- Sensor Qty
- 1 CMOS
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 60 fps
- ISO (Max)
- 3200
- Image Stabiliser
- Built-in Optical Image Stabiliser
- Face Detection
- Automatic Face Tracking technology
- Image Recording Format
- JPEG, DNG (RAW)
Exposure & White Balance
- Light Sensitivity
- ISO 100-3200
- Exposure Modes
- Automatic
- White Balance
- Automatic
- Max Shutter Speed
- 1/8000 sec
- Min Shutter Speed
- 8 sec
Lens System
- Wide-angle lens f/2.0 - wide angle
- Max View Angle
- 80 degree(s)
Additional Features
- Additional Features
- Panorama Capture
Action Camera Features
- Camera Type
- Mountable
- Time-Lapse recording
Display
- 1" LCD display
- Display Form Factor
- Built-in
- Touch Screen
- Battery Type
- Manufacturer-specific
- Details
- (included)
- Battery Life Details
- Video recording - 140 minutes (Full HD resolution)
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card
- Memory Card Included
- No
- Memory Card Max Supported Size
- 256 GB
- 12.19 cm
- 2.86 cm
- 3.444 cm
- 116 g
