DJI Osmo Action Camera
Quicklinx: FF5RWS00 Mfr#: CP.OS.00000020
Whether you want to record your world from behind a lens or be the star of the show, Osmo Action's dual screens allow you to capture it all with the touch of a button. A vivid front screen lets you frame yourself effortlessly in any setting, while the back screen delivers a crystal-clear, hyper-responsive display. This durable, versatile action camera is jam-packed with advanced technology that lets you spend less time worrying about equipment and more time living the action.
After years of providing advanced, reliable stabilization technology to filmmakers around the globe, DJI has gone one step further. RockSteady combines EIS with complex algorithms, delivering stable, shake-free footage no matter how heavy the action gets.
Dramatically enhance the dynamic range of your footage when recording with HDR video. This shooting mode delivers natural transitions between light and dark areas, capturing rich details that are often lost in environments with complex lighting.
  • Two screens, endless possibilities
    Vloggers, extreme sports enthusiasts, and filmmakers can always stay in-frame with Osmo Action's built-in front screen.
  • RockSteady stabilisation
    From the everyday to the extreme, RockSteady helps you capture every moment in smooth detail.
  • Extreme durability
    Osmo Action has a durable design that is temperature resistant down to -10°C and waterproof at depths up to 11 metres.
DJI Osmo Action - action camera
Action camera - 4K
Action Camera Type
Mountable
Memory Card Slot
microSD card
Wireless Interface
Wi-Fi, Bluetooth
Sensor Resolution
12.0 MP
Effective Sensor Resolution
Photo: 12.0 MP
Lens System
Wide-angle lens f/2.8
Focus Adjustment
Focus free
Image Stabiliser
Electronic (RockSteady)
Display
LCD display - 2.25"
Supported Battery
Li-Polymer rechargeable battery - 1300 mAh
USB-C
6.5 cm x 3.5 cm x 4.2 cm
124 g
Action camera - 4K
Camcorder Sensor Resolution
12.0 MP
Sensor Qty
1 CMOS
Effective Photo Resolution
12.0 MP
Widescreen Video Capture
Optical Sensor Type
CMOS
Optical Sensor Size
1/2.3"
Frame Rate (Max Resolution)
60 fps
ISO (Max)
3200
Image Stabiliser
HDR Mode
HDR Movie mode
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, DNG (RAW) + JPEG, DNG (RAW)
Audio Signal Format
AAC
USB-C, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2
Connectivity Features
Remote control via mobile devices, remote live view
Exposure & White Balance
Light Sensitivity
ISO 100-3200
Exposure Modes
Programme, automatic, manual
White Balance
Custom, automatic, presets
Shutter Type
Electronic
Max Shutter Speed
1/8000 sec
Min Shutter Speed
120 sec
Lens System
Wide-angle lens f/2.8 - wide angle
Focus Adjustment
Focus free
Max View Angle
145 degree(s)
Aspherical lens
Additional Features
Additional Features
Multi-picture burst, auto power save, HDR image enhancement technology, Time-Lapse recording, voice control, LCD front display, 1.4" front colour display
Action Camera Features
Camera Type
Mountable
Display
2.25" LCD display
Resolution
640 x 360 pixels
Display Form Factor
Built-in
Touch Screen
Connector Type
USB (USB Type-C)
Protection
Waterproof, freezeproof
Underwater Use
Underwater Depth
Up to 11 m
Battery Type
Lithium polymer - manufacturer-specific
Details
Battery Life Details
Video recording - 135 minutes (Full HD resolution)
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card, microSDXC Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Card
Memory Card Included
No
Memory Card Max Supported Size
256 GB
Image Storage
4000 x 3000
Video Capture
3840 x 2160 p - 60 fps , 1920 x 1080 p - 240 fps
6.5 cm
3.5 cm
4.2 cm
124 g
16.5 cm x 8.5 cm x 4.5 cm / 348 g
-10 °C
