Get closer to your subjects than ever before with the DJI Osmo+, DJI's first handheld gimbal with an integrated zoom camera. A 7× zoom, consisting of 3.5× optical and 2× digital lossless zoom, gives it a focal length ranging from 22 mm to 77 mm without sacrificing HD quality. This gives you more control over your composition than ever before.
Motion timelapse
Osmo+ helps you record the passage of time more easily than ever. Just mark where you want the camera movement to start and end, and tap 'Start' to create phenomenal moving timelapses without additional equipment. -
Advanced stabilization
The Osmo+ builds on the advanced stabilization technology introduced with the Osmo to keep the camera flat no matter how you move it, whether you are live streaming or shooting your first film, and has been optimized for ultimate stability during stills capture. -
Moving selfies
A focal distance that starts from just 0.5 meters means you are perfectly in focus when shooting an action selfie. Just triple tap the trigger button to enter Selfie Mode and start shooting. -
Detailed panorama
Take big, detailed landscape photos you will want to frame using only your smartphone and the Osmo+. Its Panorama function automatically captures and blends 9 separate photos together to create one stunning photo. -
Long exposure
Take long exposure shots with absolute crispness and sharpness, even without a tripod. The stabilization system in the Osmo+ keeps the camera totally still so you can freehand capture long exposures. -
Powerful camera
Shoot crisp 4K/30fps video and 1080p/100fps for slow motion video, with enhanced sound capture through the included FlexiMic or capture 12 megapixel stills in Adobe DNG RAW for more editing freedom.
- DJI Osmo+ - action camera
- Product Type
- Action camera - 4K
- Action Camera Type
- Mountable
- Memory Card Slot
- microSD card
- Wireless Interface
- Wireless LAN
- Sensor Resolution
- 12.76 MP
- Effective Sensor Resolution
- Photo: 12.4 MP
- Max Video Resolution
- 4096 x 2160
- Lens System
- 3.5x zoom - 4 - 14 mm - f/2.8-5.2
- Min Focus Distance
- 50 cm
- Digital Zoom
- 2x
- Image Stabiliser
- Optical (3-axis gimbal)
- Supported Battery
- Li-Polymer rechargeable battery - 1225 mAh (included)
- Product Type
- Camcorder Sensor Resolution
- 12.76 MP
- Sensor Qty
- 1 CMOS
- Effective Photo Resolution
- 12.4 MP
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/2.3"
- Frame Rate (Max Resolution)
- 25 fps
- ISO (Max)
- 3200
- Optical Zoom
- 3.5x
- Digital Zoom
- 2x
- Image Stabiliser
- Digital Video Format
- H.264
- Image Recording Format
- JPEG, DNG (RAW)
- 4096 x 2160
- Audio Signal Format
- AAC
- Interface
- Wireless LAN
- Connectivity Features
- Remote control via mobile devices, remote live view
Exposure & White Balance
- Light Sensitivity
- ISO 100-1600, ISO 100-3200
- Exposure Modes
- Automatic
- White Balance
- Automatic
- Max Shutter Speed
- 1/8000 sec
- Min Shutter Speed
- 30 sec
- Auto Exposure Bracketing
- 3, 5 steps in 2/3 EV step
Lens System
- Focal Length Equivalent to 35mm Camera
- 22 - 77mm
- 50 cm
- Max View Angle
- 92 degree(s)
Additional Features
- Additional Features
- Panorama Capture, motion Time-Lapse recording
Action Camera Features
- Camera Type
- Mountable
- Time-Lapse recording
- Included Accessories
- Battery charger, shoulder strap, microphone, storage case, wrist strap, 3-axis gimbal, rosette protection cup, mobile phone holder
- Battery Type
- Lithium polymer - manufacturer-specific
- Details
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card, microSDXC Card, microSDHC UHS-I Memory Card, microSDXC UHS-I Card
- Memory Card
- 16 GB microSDHC
- Memory Card Included
- Memory Card Max Supported Size
- 64 GB
- Image Storage
- 4000 x 3000
- Video Capture
- 4096 x 2160 - 25 fps , 4096 x 2160 - 24 fps , 3840 x 2160 - 25 fps , 3840 x 2160 - 24 fps , 3840 x 2160 - 30 fps , 2704 x 1520 - 25 fps , 2704 x 1520 - 24 fps , 2704 x 1520 - 30 fps , 1920 x 1080 - 100 fps , 1920 x 1080 - 60 fps , 1920 x 1080 - 50 fps , 1920 x 1080 - 48 fps , 1920 x 1080 - 30 fps , 1920 x 1080 - 25 fps , 1920 x 1080 - 24 fps
- 0 °C
- 40 °C
