- DJI Phantom Series Multifunctional Backpack - rucksack for drone
- Product Type
- Rucksack for drone
- Screen Size Compatibility
- 15"
- 33 cm x 21 cm x 53 cm
- 2.5 kg
- Material
- Nylon, PC/ABS
- Grey, black
- Designed For
- Phantom 4, 4 Advanced, 4 Advanced+, 4 Pro, 4 Pro+
- 33 cm
- 21 cm
- 53 cm
- 2.5 kg
- Material
- Nylon, PC/ABS
- Lining Material
- DTY twill polyurethane
- Grey, black
Carrying Case
- Rucksack
- Recommended Use
- For drone
- 15"
- Protection
- Waterproof
- Carrying Strap
- Shoulder carrying straps, top carry handle
- Closure Type
- Zipper, 2x zipper pockets
- Additional Compartments
- Notebook, remote control, 3 x batteries, 12 x propellers
- Maximum Weight Capacity
- 12.5 kg
- Designed For
- DJI Phantom 4, 4 Advanced, 4 Advanced+, 4 Pro, 4 Pro+
