MAVIC PRO PLATINUM
The Mavic Pro Platinum features a sleek design and compact body that is both powerful and alluring. A new and improved 30-minute flight time coupled with 60% noise power reduction makes the Mavic Pro Platinum DJI’s best portable drone yet.
Enhanced Endurance, Quieter Flight
Aircraft noise has been reduced by up to 4dB (60% noise power) and extended flight time to 30 minutes with new FOC sinusoidal driver ESCs and 8331 propellers for a quieter, more enjoyable flight experience.
Drone Code
Please take a moment to familiarise yourself with the Drone code before flying your drone. When you fly a drone in the UK it is your responsibility to be aware of the rules that are in place to keep everyone safe. Follow these simple steps to make sure you are flying safely and legally.
On 30 July the UK drone rules changed to make it against the law to fly above 400ft (120m) and to make it against the law to fly your drone within 1km of an airport or airfield boundary.
- Always keep your drone in sight
- Stay below 400ft (120m) to comply with the dronecode
- Every time you fly your drone you must follow the manufacturer’s instructions
- Keep the right distance from people and property – People & Properties 150ft (50m), Crowds and built up areas 500ft (150m)
- You are legally responsible for each flight
- Stay well away from aircraft, airports and airfields. If your drone endangers the safety of an aircraft it is a criminal offence.
For more information visit: https://dronesafe.uk/drone-code/
- DJI Mavic Pro Platinum Fly More Combo - quadcopter
- Product Type
- Quadcopter
- Category
- Vehicles - drones
- Compatibility
- iPhone, iPad, Android phone
- Camera
- Included - 12.71 Megapixel
- Max Speed
- 65 kilometers per hour
- Navigation
- GPS/GLONASS receiver
- Interface
- Wi-Fi
- 734 g
- Product Type
- Quadcopter
- Category
- Vehicles - drones
- Compatibility
- Remote Control
- Yes - 2.4 GHz - max operating distance: 7 km
- Power Source
- Battery
- Max Speed
- Card Reader
- microSD up to 64 GB
- Micro-USB cable, power cable, charger, remote controller, 16 GB MicroSD card, gimbal clamp, gimbal cover, car charger, battery to power bank adapter, shoulder bag, battery charging hub, RC cable (Lightning connector), RC cable (USB-C connector), RC cable (micro-USB connector), 2 RC cable sliders (small), 2 x gold tip propellers (pair), 3 intelligent flight batteries, 2 RC cable sliders (large), 3 x platinum tip propellers (pair), obstacle avoidance system
RC Vehicle
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.3 metres
- Navigation
- Interface
- Wi-Fi
- Wi-Fi Bands
- 2.4 GHz (1 band) / 5 GHz (2 bands)
Gimbal
- Control Angle Range
- -90 to 30°
Digital Camera
- Sensor Resolution
- 12.71 Megapixel
- Capture Formats
- MPEG-4, H.264, MP4, MOV
- Video Recorder Resolutions
- 1280 x 720 (720p), 1920 x 1080 (1080p), 3840 x 2160 (2160p), 4096 x 2160, 2720 x 1530
- Frame Rate
- 24 frames per second
- Still Image Formats
- JPEG, DNG
- Max View Angle
- 78.8 degree(s)
- Rechargeable Battery
- Rechargeable
- Supported Battery Configurations
- 3S
- Technology
- Lithium polymer
- Voltage
- 11.4 V
- Capacity
- 3830 mAh
- Run Time
- Up to 30 min
- Localisation
- United Kingdom
- 734 g
Choking Hazard Warnings
- Dimensions & Weight Details
- With gimbal cover - 743 g , Folded - 8.3 cm x 19.8 cm x 8.3 cm x 734 g
- 0 °C
- 40 °C
