DJI Mavic Pro Platinum Drone
Quicklinx: DDWTWS00 Mfr#: CP.PT.00073.01
MAVIC PRO PLATINUM
The Mavic Pro Platinum features a sleek design and compact body that is both powerful and alluring. A new and improved 30-minute flight time coupled with 60% noise power reduction makes the Mavic Pro Platinum DJI’s best portable drone yet.
Enhanced Endurance, Quieter Flight
Aircraft noise has been reduced by up to 4dB (60% noise power) and extended flight time to 30 minutes with new FOC sinusoidal driver ESCs and 8331 propellers for a quieter, more enjoyable flight experience.
Drone Code
Please take a moment to familiarise yourself with the Drone code before flying your drone. When you fly a drone in the UK it is your responsibility to be aware of the rules that are in place to keep everyone safe. Follow these simple steps to make sure you are flying safely and legally.
On 30 July the UK drone rules changed to make it against the law to fly above 400ft (120m) and to make it against the law to fly your drone within 1km of an airport or airfield boundary.
  1. Always keep your drone in sight
  2. Stay below 400ft (120m) to comply with the dronecode
  3. Every time you fly your drone you must follow the manufacturer’s instructions
  4. Keep the right distance from people and property – People & Properties 150ft (50m), Crowds and built up areas 500ft (150m)
  5. You are legally responsible for each flight
  6. Stay well away from aircraft, airports and airfields. If your drone endangers the safety of an aircraft it is a criminal offence.
For more information visit: https://dronesafe.uk/drone-code/
DJI Mavic Pro Platinum - quadcopter
Quadcopter
Included Items
Micro-USB cable, power cable, charger, remote controller, 16 GB MicroSD card, gimbal clamp, 4 RC cable sliders, 3 pairs of propellers, lightning connector, 3 RC cables
Category
Vehicles - drones
Compatibility
iPhone, iPad, Android phone
Camera
Included - 12.71 Megapixel
Max Speed
65 kilometers per hour
Navigation
GPS/GLONASS receiver
Wi-Fi
734 g
Quadcopter
Included Items
Category
Vehicles - drones
Compatibility
Size
335 mm
Remote Control
Yes - 2.4 GHz - max operating distance: 7 km
Power Source
Max Speed
Supported Flash Memory Cards
microSD Class 10 or UHS-I up to 128 GB
Obstacle avoidance system
RC Vehicle
Vertical Hovering Accuracy
+/- 0.1 metres
Horizontal Hovering Accuracy
+/- 0.3 metres
Max Vertical Velocity
5 metres per second
Max Horizontal Velocity
18.1 metres per second
Navigation
Wi-Fi
Wi-Fi Bands
2.4 GHz (1 band) / 5 GHz (2 bands)
Gimbal
Control Angle Range
-90 to 30° (pitch), 0 to 90° (roll)
Digital Camera
Sensor Resolution
12.71 Megapixel
Image Sensor Type
CMOS
Capture Formats
MP4, MOV (MPEG-4 AVC/H.264)
Video Recorder Resolutions
1280 x 720 (720p), 1920 x 1080 (1080p), 3840 x 2160 (2160p), 4096 x 2160, 2720 x 1530
Frame Rate
120 frames per second
Still Image Formats
JPEG, DNG
Still Image Resolutions
4000 x 3000
Max View Angle
78.8 degree(s)
Rechargeable Battery
Rechargeable
Supported Battery Configurations
3S
Lithium polymer
Voltage
11.4 V
3830 mAh
Run Time
Up to 30 min
Supported OS
Android 4.1.2 (Jelly Bean) or later, Apple iOS 9 or later
734 g
Choking Hazard Warnings
Dimensions & Weight Details
With gimbal cover - 743 g , Folded - 8.3 cm x 19.8 cm x 8.3 cm
