MAVIC PRO PLATINUM
The Mavic Pro Platinum features a sleek design and compact body that is both powerful and alluring. A new and improved 30-minute flight time coupled with 60% noise power reduction makes the Mavic Pro Platinum DJI’s best portable drone yet.
Enhanced Endurance, Quieter Flight
Aircraft noise has been reduced by up to 4dB (60% noise power) and extended flight time to 30 minutes with new FOC sinusoidal driver ESCs and 8331 propellers for a quieter, more enjoyable flight experience.
Drone Code
Please take a moment to familiarise yourself with the Drone code before flying your drone. When you fly a drone in the UK it is your responsibility to be aware of the rules that are in place to keep everyone safe. Follow these simple steps to make sure you are flying safely and legally.
On 30 July the UK drone rules changed to make it against the law to fly above 400ft (120m) and to make it against the law to fly your drone within 1km of an airport or airfield boundary.
- Always keep your drone in sight
- Stay below 400ft (120m) to comply with the dronecode
- Every time you fly your drone you must follow the manufacturer’s instructions
- Keep the right distance from people and property – People & Properties 150ft (50m), Crowds and built up areas 500ft (150m)
- You are legally responsible for each flight
- Stay well away from aircraft, airports and airfields. If your drone endangers the safety of an aircraft it is a criminal offence.
For more information visit: https://dronesafe.uk/drone-code/
- DJI Mavic Pro Platinum - quadcopter
- Product Type
- Quadcopter
- Included Items
- Micro-USB cable, power cable, charger, remote controller, 16 GB MicroSD card, gimbal clamp, 4 RC cable sliders, 3 pairs of propellers, lightning connector, 3 RC cables
- Category
- Vehicles - drones
- Compatibility
- iPhone, iPad, Android phone
- Camera
- Included - 12.71 Megapixel
- Max Speed
- 65 kilometers per hour
- Navigation
- GPS/GLONASS receiver
- Interface
- Wi-Fi
- 734 g
- Product Type
- Quadcopter
- Included Items
- Category
- Vehicles - drones
- Compatibility
- Size
- 335 mm
- Remote Control
- Yes - 2.4 GHz - max operating distance: 7 km
- Power Source
- Battery
- Max Speed
- Supported Flash Memory Cards
- microSD Class 10 or UHS-I up to 128 GB
- Obstacle avoidance system
RC Vehicle
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.3 metres
- Max Vertical Velocity
- 5 metres per second
- Max Horizontal Velocity
- 18.1 metres per second
- Max Ascent Speed
- Max Descent Speed
- 3 metres per second
- Navigation
- Interface
- Wi-Fi
- Wi-Fi Bands
- 2.4 GHz (1 band) / 5 GHz (2 bands)
Gimbal
- Control Angle Range
- -90 to 30° (pitch), 0 to 90° (roll)
Digital Camera
- Sensor Resolution
- 12.71 Megapixel
- Image Sensor Type
- CMOS
- Capture Formats
- MP4, MOV (MPEG-4 AVC/H.264)
- Video Recorder Resolutions
- 1280 x 720 (720p), 1920 x 1080 (1080p), 3840 x 2160 (2160p), 4096 x 2160, 2720 x 1530
- Frame Rate
- 120 frames per second
- Still Image Formats
- JPEG, DNG
- Still Image Resolutions
- 4000 x 3000
- Max View Angle
- 78.8 degree(s)
- Rechargeable Battery
- Rechargeable
- Supported Battery Configurations
- 3S
- Technology
- Lithium polymer
- Voltage
- 11.4 V
- Capacity
- 3830 mAh
- Run Time
- Up to 30 min
- Supported OS
- Android 4.1.2 (Jelly Bean) or later, Apple iOS 9 or later
- 734 g
Choking Hazard Warnings
- Dimensions & Weight Details
- With gimbal cover - 743 g , Folded - 8.3 cm x 19.8 cm x 8.3 cm
- 0 °C
- 40 °C
