                Imaging capabilitiesThe 20 megapixel CMOS sensor allows for image quality, including still images and 4K video recording. Capture details and colors accurately, making it suitable for a variety of professional applications.
                Battery performanceThe lithium cobalt oxide battery with a capacity of 5000 mAh provides reliable power, ensuring that the drone can remain airborne for extended periods. Its rechargeable design also supports multiple uses.
                Navigation and controlEquipped with GPS/GLONASS/BeiDou/GALILEO navigation systems, this drone offers precise positioning along with an accomplished RC Pro remote control that extends the operating range up to 15 km.
                Design for outdoor useDesigned to operate efficiently in various weather conditions, the DJI Mavic 3 Multispectral can withstand temperatures ranging from -10°C to 40°C, making it a suitable choice for outdoor applications.
- DJI Mavic 3 Multispectral - drone
- Product Type
- Drone
- Included Items
- Carrying case, charger, intelligent flight battery, pair of propellers, DJI RC remote controller, power cable, USB-C cable, manual
- Category
- Vehicles - drones
- Camera
- Included - 20 Megapixel
- Max Speed
- 15 metres per second
- Navigation
- GPS/GLONASS/BeiDou/GALILEO receiver
- Interface
- Wi-Fi, Bluetooth
- Outdoor
- 28.3 cm
- 34.75 cm
- 13.96 cm
- 951 g
- Product Type
- Drone
- Included Items
- Category
- Vehicles - drones
- Size
- 380.1 mm
- Remote Control
- Yes - 5.8 GHz - max operating distance: 15 km
- Power Source
- Battery
- Outdoor
- Max Speed
- Supported Flash Memory Cards
- microSDHC, microSDXC up to 512 GB
- Obstacle avoidance system
RC Vehicle
- Take-Off Weight
- 1050 g
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.3 metres
- Max Angular Velocity
- 200° per second
- Max Tilt Angle
- 35°
- Max Ascent Speed
- 8 metres per second
- Max Descent Speed
- 6 metres per second
- Max Wind Speed Resistance
- 12 metres per second
- Navigation
- Interface
- Wi-Fi, Bluetooth
- Wi-Fi Bands
- 2.4 GHz, 5.8 GHz
Gimbal
- Control Angle Range
- -90 to 35° (pitch)
- Max Speed
- 100° per second (tilt)
Digital Camera
- Sensor Resolution
- 20 Megapixel
- Image Sensor Type
- CMOS
- Focus Adjustment
- Manual
- Capture Formats
- MP4 (MPEG-4 AVC/H.264)
- Video Recorder Resolutions
- 3840 x 2160 (4K) at 30 fps, 1920 x 1080 (1080p) 30fps
- Still Image Formats
- DNG, JPEG, RAW
- Still Image Resolutions
- 5280 x 3956
- Max View Angle
- 84 degree(s)
- Rechargeable Battery
- Rechargeable
- Supported Battery Configurations
- 4S
- Technology
- Lithium cobalt oxide
- Voltage
- 15.4 V
- Capacity
- 5000 mAh
- Run Time
- Up to 43 min
- IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, Bluetooth 5.1, IEEE 802.11ax (Wi-Fi 6)
- Dimensions
- 34.75 cm x 28.3 cm x 13.96 cm
- 951 g
Choking Hazard Warnings
- Dimensions & Weight Details
- Folded without propellers - 9.63 cm x 22.3 cm x 12.22 cm , Unfolded - 28.3 cm x 34.75 cm x 13.96 cm , Battery - 335.5 g
- -10 °C
- 40 °C
