The Mavic 2 Zoom sports a 1/2.3 inch 12-megapixel sensor and two-times optical zoom lens (24mm - 48mm, 35 equivalent), allowing users to capture everything from wide angle to mid-range shots for more creative options.
More expressive mid-range shots
Compared to a 24mm wide angle lens, the 48mm telephoto lens compresses your perspective, enhancing the parallax effect for a classic cinematic look. Now a whole new world of aerial photography is open to explore with even more epic, cinematic shots. -
A worry-free way to find a view
When shooting Full HD video, 4x lossless zoom (including 2x optical zoom) gives you a closer view of faraway subjects, making unique scenes more accessible to capture at a distance. This option also helps you maintain a safer distance from buildings, vehicles, animals, and people. -
Quick and accurate focus
Hybrid autofocus on the Mavic 2 Zoom combines phase and contrast detection for higher focus accuracy with an increased focus speed of up to 40% more than before. The autofocus tracking system makes subjects appear clear and sharp when zooming in and out. -
Zoom during flight
Dolly Zoom is a new QuickShot for the Mavic 2 Zoom, offering an otherworldly perspective in a fully-integrated drone. Dolly Zoom automatically adjusts focus when flying, adding an intense, warping visual effect to your video. When flying manually, you can also set proper focus speed values for even more creative shot options. -
Super resolution photos
The Mavic 2 Zoom also has a brand new Super Resolution feature - an asset when capturing the vivid details your landscape photography deserves. When taking a picture with a 24 mm equivalent field-of-view, the camera will capture and patch nine photos with its telephoto lens, resulting in a 48-megapixel super resolution photo. Compared to ordinary panoramas, the super resolution photos retain the original look of the shooting targets with a more accurate composition.
- DJI Mavic 2 Zoom - quadcopter
- Product Type
- Quadcopter
- Category
- Vehicles - drones
- Compatibility
- iPhone, iPad, Android phone
- Camera
- Included - 12 Megapixel
- Max Speed
- 72 kilometers per hour
- Navigation
- GPS/GLONASS receiver
- Interface
- Wi-Fi
- 24.2 cm
- 32.2 cm
- 8.4 cm
- Product Type
- Quadcopter
- Category
- Vehicles - drones
- Compatibility
- Size
- 354 mm
- Remote Control
- Yes - 2.4 GHz - max operating distance: 8 km
- Power Source
- Battery
- Max Speed
- Card Reader
- microSDXC UHS-I Memory Card up to 128 GB
- Battery charger, remote controller, camera with gimbal, intelligent flight battery, obstacle avoidance system
RC Vehicle
- Take-Off Weight
- 907 g
- Vertical Hovering Accuracy
- +/- 0.1 metres
- Horizontal Hovering Accuracy
- +/- 0.3 metres
- Max Angular Velocity
- 200° per second
- Max Tilt Angle
- 35°
- Max Vertical Velocity
- 5 metres per second
- Max Horizontal Velocity
- 20 metres per second
- Navigation
- Interface
- Wi-Fi
Gimbal
- Control Angle Range
- -90 to 30° (tilt), -75 to 75° (pan)
- Max Speed
- 120° per second (tilt)
Digital Camera
- Sensor Resolution
- 12 Megapixel
- Image Sensor Type
- CMOS
- Capture Formats
- MOV (MPEG-4 AVC/H.264), MP4 (MPEG-4 AVC/H.264)
- Video Recorder Resolutions
- 1920 x 1080 (1080p), 3840 x 2160 (2160p), 2688 x 1512
- Frame Rate
- 30 frames per second
- Still Image Formats
- JPEG, DNG
- Still Image Resolutions
- 4000 x 3000
- Max View Angle
- 83 degree(s)
- Rechargeable Battery
- Rechargeable
- Supported Battery Configurations
- 4S
- Technology
- Lithium polymer
- Voltage
- 15.4 V
- Capacity
- 3850 mAh
- Run Time
- Up to 31 min
- Dimensions
- 32.2 cm x 24.2 cm x 8.4 cm
Choking Hazard Warnings
- Dimensions & Weight Details
- Folded - 9.1 cm x 21.4 cm x 8.4 cm , Battery - 297 g
- -10 °C
- 40 °C
