Professional image quality
Integrated into the Inspire 2 is the advanced image processing system. It is built into the aircraft nose and works with any camera connected through the dedicated gimbal port. -
Sense and avoid
Forward and downward vision systems enable the Inspire 2 to detect obstacles ahead, allowing for protected flight at a controllable attitude angle of 25°. Upward facing infrared sensors scan obstacles above, adding protection when flying in enclosed spaces. -
Spotlight Pro
Spotlight Pro is a powerful tracking mode that allows even single pilots to capture complex, dramatic images. It uses advanced visual tracking algorithms to lock onto a subject during flight, regardless of the direction that the Inspire 2 flies, creating shots that would once have required a dedicated camera operator. If the gimbal comes close to reaching its rotation limits, the Inspire 2 itself will rotate in the same direction without affecting flight control or the shot being captured to free up gimbal movement. -
Smart return to home
Forward and downward vision systems allow the Inspire 2 to create a real-time map of its flight route as it flies. If the video transmission system signal is lost and Smart Return Home is enabled, it is able to fly home along its original route, and change to a straight line when it regains a signal.
