The DJI Goggles are comfortable goggles designed for seamless FPV flying with DJI products.They combine a pair of ultra-high quality screens, long range low lag wireless connectivity, and direct control of photo and video capture. With Intelligent Flight Modes like ActiveTrack, TapFly, Terrain Follow, Cinematic Mode and Tripod mode, a totally new flying dimension is created.
Low lag transmission
DJI Goggles are able to offer both 720p/60fps and close range 1080p/30fps viewing with an extremely low latency.Through DJI's OcuSync wireless transmission system, up to four devices can be connected to the Mavic Pro simultaneously. Antennas built into the headband ensure 360° of coverage, offering a reliable connection even if the aircraft is flying behind you. Share the fun of immersive flying with friends by giving them a bird's eye view of the world as you pilot their experience. -
High quality optics
Each screen packs its pixels together tightly so you see a clean, cohesive image with no latticing. -
Head tracking
Your head movements control both aircraft yaw and camera tilt in Head Tracking Flight mode as with remote controller sticks. All you need to do is turn left or right to yaw left or right, and straighten your head to stop turning. In Head Tracking Gimbal mode only the gimbal will move without affecting yaw. -
Touchpad & remote controller
Access to key intelligent features through a touchpad integrated into the DJI Goggles or 5D button on the Mavic Pro controller makes navigating the internal menu system easy and intuitive. -
Intelligent flight
DJI Goggles are a perfect pair with DJI's Intelligent Flight Mode: Fixed-Wing Mode. In this mode, the aircraft doesn't turn left or right but instead flies forward with enough rotational movement for realistic flight simulation. Combined with Head Tracking Mode, you can use your head to control the Mavic Pro for a fully realized flight experience. An AR trajectory prediction feature in Fixed-Wing Mode makes using this mode in complex environments safer. Other Intelligent Flight Modes include Terrain Follow, ActiveTrack, TapFly, Cinematic Mode and Tripod Mode. -
Comfortable and flexible
A unique solid headband design balances and spreads the weight of DJI Goggles around the head evenly, minimizing pressure on the face and keeping them comfortable to wear for hours. People who wear glasses are also able to wear them comfortably. The screen portion of DJI Goggles can be flipped up to glimpse the real world, or detached entirely for easy storage and portability.
- DJI Goggles - virtual reality headset - Full HD (1080p)
- Virtual reality headset
- Remote control, touchpad, antenna, microSD card reader
- Sensors
- Accelerometer, proximity sensor, gyro sensor, head tracking sensor
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 30 Hz
- Resolution per Eye
- 5" - 1920 x 1080
- Field of View
- 85°
- Battery Run Time
- Up to 6 hours
- White
- Dimensions (WxDxH) - body
- 19.5 cm x 15.5 cm x 11 cm
- 495 g
- Localisation
- United Kingdom
- HDCP 1.2
- Display Type
- Built-in Devices
- Antenna, microSD card reader
- Aspect Ratio
- 16:9
- Native Resolution
- HDCP
- White
- 19.5 cm x 15.5 cm x 11 cm - body
- 495 g
VR Headset
- 1920 x 1080
- Diagonal Size per Eye
- 5"
- Field of View
- 85°
- Sensors
- Control Type
- Touchpad
Audio
- Speakers
Input
- Micro-USB , HDMI , Headphones
- Included Accessories
- Cleaning cloth, headband, wire clip
- Cables Included
- 1 x micro-USB cable , 1 x HDMI cable
- HDCP 1.2
- Localisation
- United Kingdom
- Voltage Required
- AC 120/230 V (50/60 Hz)
- Capacity
- 9440 mAh
- Run Time (Up To)
- 6 hours
- Dimensions & Weight Details
- Headband - width: 25.5 cm - depth: 20.5 cm - height: 9.2 cm - weight: 500 g
- 0 °C
- 40 °C
