DJI Goggles - for DJI Drones
Quicklinx: CYLFWS00 Mfr#: CP.PT.000671
22 in stock
£415.83 ex VAT
£498.99 inc VAT
The DJI Goggles are comfortable goggles designed for seamless FPV flying with DJI products.They combine a pair of ultra-high quality screens, long range low lag wireless connectivity, and direct control of photo and video capture. With Intelligent Flight Modes like ActiveTrack, TapFly, Terrain Follow, Cinematic Mode and Tripod mode, a totally new flying dimension is created.
  • Low lag transmission
    DJI Goggles are able to offer both 720p/60fps and close range 1080p/30fps viewing with an extremely low latency.Through DJI's OcuSync wireless transmission system, up to four devices can be connected to the Mavic Pro simultaneously. Antennas built into the headband ensure 360° of coverage, offering a reliable connection even if the aircraft is flying behind you. Share the fun of immersive flying with friends by giving them a bird's eye view of the world as you pilot their experience.
  • High quality optics
    Each screen packs its pixels together tightly so you see a clean, cohesive image with no latticing.
  • Head tracking
    Your head movements control both aircraft yaw and camera tilt in Head Tracking Flight mode as with remote controller sticks. All you need to do is turn left or right to yaw left or right, and straighten your head to stop turning. In Head Tracking Gimbal mode only the gimbal will move without affecting yaw.
  • Touchpad & remote controller
    Access to key intelligent features through a touchpad integrated into the DJI Goggles or 5D button on the Mavic Pro controller makes navigating the internal menu system easy and intuitive.
  • Intelligent flight
    DJI Goggles are a perfect pair with DJI's Intelligent Flight Mode: Fixed-Wing Mode. In this mode, the aircraft doesn't turn left or right but instead flies forward with enough rotational movement for realistic flight simulation. Combined with Head Tracking Mode, you can use your head to control the Mavic Pro for a fully realized flight experience. An AR trajectory prediction feature in Fixed-Wing Mode makes using this mode in complex environments safer. Other Intelligent Flight Modes include Terrain Follow, ActiveTrack, TapFly, Cinematic Mode and Tripod Mode.
  • Comfortable and flexible
    A unique solid headband design balances and spreads the weight of DJI Goggles around the head evenly, minimizing pressure on the face and keeping them comfortable to wear for hours. People who wear glasses are also able to wear them comfortably. The screen portion of DJI Goggles can be flipped up to glimpse the real world, or detached entirely for easy storage and portability.
DJI Goggles - virtual reality headset - Full HD (1080p)
Virtual reality headset
Remote control, touchpad, antenna, microSD card reader
Sensors
Accelerometer, proximity sensor, gyro sensor, head tracking sensor
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 30 Hz
Resolution per Eye
5" - 1920 x 1080
Field of View
85°
Battery Run Time
Up to 6 hours
White
Dimensions (WxDxH) - body
19.5 cm x 15.5 cm x 11 cm
495 g
United Kingdom
HDCP 1.2
Display Type
Built-in Devices
Antenna, microSD card reader
Aspect Ratio
16:9
Native Resolution
HDCP
White
19.5 cm x 15.5 cm x 11 cm - body
495 g
VR Headset
Resolution per Eye
1920 x 1080
Diagonal Size per Eye
5"
Field of View
85°
Sensors
Control Type
Touchpad
Audio
Speakers
Input
Micro-USB , HDMI , Headphones
Cleaning cloth, headband, wire clip
1 x micro-USB cable , 1 x HDMI cable
HDCP 1.2
United Kingdom
9440 mAh
Run Time (Up To)
6 hours
Dimensions & Weight Details
Headband - width: 25.5 cm - depth: 20.5 cm - height: 9.2 cm - weight: 500 g
Brand: DJI
Price Range Ex VAT: 300 - 500
