The Ultra Skin PRO accompanies you reliably and provides custom-fitted protection for your notebook or Ultrabook. The especially lightweight case combines compact design with robust materials. The material selection makes the Ultra Skin PRO built to last. The case is made of durable neoprene, combined with nylon and real leather details. A soft synthetic fur lining on the inside protects your notebook from scratches. The flexible accessory compartment on the front provides storage space for a power bank, charging cable, mobile phone and other personal items. The protective case is equipped with two zippers. This allows you to charge your notebook or Ultrabook conveniently, without sacrificing maximum protection.
- DICOTA Ultra Skin PRO Laptop Sleeve 14.1" - notebook sleeve
- Product Type
- Notebook sleeve
- Product Material
- Neoprene
- 26.4 cm x 36.5 cm x 1.3 cm
- 200 g
- Notebook Compatibility
- 14.1"
- Scratch-proof, zippered
- Limited lifetime warranty
- Product Type
- Notebook sleeve
- Product Material
- Neoprene
- 26.4 cm
- 36.5 cm
- 1.3 cm
- 200 g
- 14.1"
- Notebook Compatibility Dimensions
- 35 cm x 24.5 cm x 3 cm
- Additional Compartments
- Personal accessories
- Limited warranty: - lifetime
