Dicota Top Traveller Roller PRO 14-15.6
Quicklinx: FS4DWS00 Mfr#: D30848
£158.55 ex VAT
£190.26 inc VAT
Travel '1st class' with Top Traveler Roller PRO. The trolley reliably accompanies you everywhere and meets the high standards of quality, functionality and protection: fit-all system holds notebooks of various sizes, anti-slip technology ensures your notebook and the shoulder strap do not slide and the light and particularly shock-absorbent EVA frame protection offers top-quality protection for your device. The perforated and thus light EVA foam material in the sealable notebook compartment perfectly protects the edges of your device with a remarkable saving in weight. Enjoy the high level of flexibility with the integrated removable notebook bag. The anti-slip technology coating ensures perfect grip for your notebook in the compartment and the adjustable padded shoulder strap. Excellent protection for your tablet thanks to the EVA-shaped compartment with extra-soft nylex inner lining. Generous storage space for printer, projector and your documents. The front pocket with key fob and insert pockets allows you to organize your personal equipment and provides space for additional mobile accessories. Zip compartment for IDs. High level of comfort while wearing or rolling the bag thanks to high-quality handles, made from genuine leather, replaceable wheels, integrated telescopic handle and trolley fastening strap. Bag bottom made from waterproof material Address label - Dicota's attention to detail makes this bag one of your extremely reliable business partners!
DICOTA Top Traveller Roller PRO 15.6" - trolley
Trolley
Product Material
Nylon, ethylene vinyl acetate (EVA)
44.5 cm x 25 cm x 33 cm
4.4 kg
Notebook Compatibility
15.6"
Waterproof, adjustable shoulder strap, zipper pocket, padded shoulder strap, elastic strap fastening, slip pocket, molded wheels, lockable
Carrying Strap
Hand grip, shoulder carrying strap, trolley strap
Trolley
Product Material
44.5 cm
25 cm
33 cm
4.4 kg
15.6"
Notebook Compatibility Dimensions
38 cm x 26.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, power adapter, passport, documents, pens, wallet, business cards, mobile accessories, Apple iPad
Carrying Strap
Wheels, lockable
Limited warranty: - 2 years
Brand: Dicota
