Dicota Top Traveller BASE 15-15.6 - Black
Quicklinx: DJKVWS00 Mfr#: D31325
Type: Bags & Cases
More than 50 in stock
£20.74 ex VAT
£24.88 inc VAT
Live smart with Top Traveller BASE! The handy toploader case protects your notebook perfectly thanks to the cushioned notebook compartment with metal wire frame. This lightweight notebook case guarantees flexible mobility - both professionally and privately.
Your 15-15.6" notebook is optimally protected with high density foam padding. The case also has space for your documents. You can store mobile accessories in the front pocket. So all your important things are handy at all times. The shoulder strap is removable and the length can be adjusted. Thanks to its padded neoprene carry handle, the case is comfortable to hold and can be instantly fixed to the trolley using the integrated strap – the smart case from the lightweight class!
DICOTA Top Traveller BASE notebook carrying case
Notebook carrying case
Product Material
Polyester, neoprene
41 cm x 8.5 cm x 29.5 cm
700 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
15" - 15.6" / 38.1 cm - 39.6 cm
Foam padding, adjustable shoulder strap, High-Density Foam (HDF), metal frame, front pocket
Carrying Strap
Trolley strap, removable shoulder strap, padded top handles
Product Material
Polyester, neoprene
41 cm
8.5 cm
29.5 cm
700 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3.5 cm
Additional Compartments
Mobile phone, documents, pens, mobile accessories
Carrying Strap
Closure Type
Zipper
Compartments Quantity
2
Limited warranty - lifetime
Dicota Top Traveller BASE 15-15.6 - Black Bundle deal on Dicota Top Traveller BASE 15-15.6 - Black
£113.77
Type: Bags & Cases
Brand: Dicota
Price Range Ex VAT: 0 - 50
