Dicota Skin URBAN 15 - Grey
Quicklinx: FS3RWS00 Mfr#: D31753
Elegant and minimalistic: the high-quality design of the URBAN skin perfectly matches the shape of your device. The skin features a soft faux fur lining that protects it from scratches and dust. The compact sleeve is made of an elastic neoprene material. It is light, durable and powerful thanks to its sturdy design.
DICOTA Skin URBAN - notebook sleeve
Notebook sleeve
Grey
Product Material
Neoprene
36 cm x 2 cm x 26.5 cm
230 g
Notebook Compatibility
15"
Apple MacBook Pro (15.4 in)
Notebook sleeve
Product Material
Neoprene
36 cm
2 cm
26.5 cm
230 g
15"
Notebook Compatibility Dimensions
35 cm x 24.5 cm x 2.5 cm
Closure Type
Zipper
Lining Material
Faux fur
Grey
Limited warranty: - lifetime
