For anybody who wants to transport their notebook in a light-weight and flexible fashion. Skin BASE is made of robust and especially elastic neoprene and perfectly adapts to the form of your notebook like a second skin. The zipper is fitted with an extra surface on the inside in order to avoid scratches on the notebook.
- DICOTA Skin BASE - notebook sleeve
- Product Type
- Notebook sleeve
- Blue
- Product Material
- Robust synthetic neoprene
- 35 cm x 2.7 cm x 25 cm
- 170 g
- Notebook Compatibility
- 14.1"
- Notebook Supported Sizes
- 13" - 14.1" / 33 cm - 35.8 cm
- Zippered
- Limited lifetime warranty
- Product Type
- Notebook sleeve
- Product Material
- 35 cm
- 2.7 cm
- 25 cm
- 170 g
- 14.1"
- Notebook Compatibility Dimensions
- 35 cm x 24.5 cm x 3 cm
- Zippered
- Blue
- Limited warranty: - lifetime
