This DICOTA lock works without a key and fits almost all standard lock slots. Notebooks, projectors, printers and monitors can be effectively secured. With a length of 200 cm. The 4-digit combination allows you to set your individual number code and up to 10,000 possible number combinations ensure the necessary security.
Enhanced security
This security cable lock from DICOTA is designed to provide a robust layer of protection for PCs. Made from high-grade steel, it's built to withstand attempts at tampering or cutting, ensuring your device remains secure in public spaces or offices. -
User-friendly design
Featuring a combination lock, this security solution offers a convenient, keyless way to secure your devices. The ease of setting and changing combinations means you can maintain high security without the hassle of managing keys.
 - DICOTA - security cable lock
- Product Type
 - Security cable lock
- Product Material
 - Steel
- Length
 - 2 m
 - 200 g
 - Combination lock
- Product Type
- Product Material
 - Steel
- Length
 - 2 m
 - 200 g
 - Combination lock
