Dicota Perfect Skin 15-16"
Quicklinx: HV4TWS00 Mfr#: D31188-RPET
£13.22 ex VAT
£15.86 inc VAT
For anybody who wants to temporarily transport their Notebook in a light-weight and flexible fashion. PerfectSkin is made of robust and especially elastic neoprene and perfectly adapts to the form of your Notebook like a second skin. It gives the best guaranty against surface scratches and other dents and damages. Another advantage: The zipper is fitted with an extra surface on the inside in order to avoid scratches on the Notebook.
  • Eco-friendly Materials
    Crafted from 100% recycled fabric, this sleeve protects your laptop and supports environmental sustainability.
  • Water-repellent Protection
    The water-repellent feature ensures that your device stays dry even in unexpected weather conditions.
  • Lightweight and Compact
    The lightweight design makes it easy to carry, perfect for students and professionals on the go.
  • Secure Zipper Closure
    The reliable zipper closure allows for quick access while ensuring that your laptop remains safely tucked inside.
  • Compatibility with Various Sizes
    Designed to fit laptops ranging from 15 to 15.6 inches, accommodating multiple models and brands.
DICOTA PERFECT - notebook sleeve
Notebook sleeve
Product Material
Neoprene, 100% recycled fabric
40 cm x 27 cm x 2.5 cm
210 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
15" - 15.6" / 38.1 cm - 39.6 cm
Scratch protection, lightweight design water repellent
Notebook sleeve
Product Material
40 cm
27 cm
2.5 cm
210 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3 cm
Closure Type
Zipper
Water repellent
Limited warranty: - lifetime , Limited warranty: Germany - 30 years
Brand: Dicota
