Dicota Multi Plus BASE 15-17.3" - Black
Quicklinx: DQZCWS00 Mfr#: D30492-V1
Type: Bags & Cases
£18.95 ex VAT
£22.74 inc VAT
Lightweight notebook case with protective function and document compartment
Live smart with MULTI PLUS BASE! The handy clamshell case with additional document compartment protects your notebook perfectly thanks to the cushioned notebook compartment with metal wire frame. This lightweight notebook case guarantees flexible mobility - both professionally and privately. Available in May 2014.
Your 15-17.3" notebook is not only optimally protected, it can also be securely fixed into the compartment using a strap. You can store documents in the provided zipper compartment. The front pocket with slip pockets allows you to organise your personal items such as mobile phone and pens. So all your important things are handy at all times. The shoulder strap is removable. Thanks to its comfortable carry handle, the case is comfortable to hold and can be instantly fixed to the trolley using the integrated strap – the smart case from the lightweight class!
DICOTA Base Pro notebook carrying case
Notebook carrying case
Product Material
Polyester
Notebook Compatibility
17.3"
Zippered, inside pocket
Carrying Strap
Hand grip, shoulder carrying strap
Product Material
Polyester
17.3"
Notebook Compatibility Dimensions
42 cm x 29.5 cm x 4.5 cm
Carrying Strap
Dicota Multi Plus BASE 15-17.3 Bundle deal on Dicota Multi Plus BASE 15-17.3" - Black
£118.12
Type: Bags & Cases
Brand: Dicota
Price Range Ex VAT: 0 - 50
