Dicota Multi BASE 15-17.3 - Red
Quicklinx: FS2QWS00 Mfr#: D30917
Live smart with Multi BASE! The handy clamshell case protects your notebook perfectly thanks to the cushioned notebook compartment with metal wire frame. This lightweight notebook case guarantees flexible mobility - both professionally and privately. Give your life a little color.
Your notebook is not only optimally protected, it can also be fixed securely in the compartment using a strap. The front pocket provides space for accessories. So all your important things are handy at all times. The shoulder strap is removable. Thanks to its comfortable carry handle, the case is comfortable to hold and can be instantly fixed to the trolley using the integrated strap - the smart case from the lightweight class!
DICOTA Multi BASE Laptop Bag 17.3" - notebook carrying case
Notebook carrying case
Red
Product Material
Polyester
Notebook Compatibility
17.3"
Padded, removable shoulder strap
Carrying Strap
Hand grip, shoulder carrying strap, trolley strap
Product Material
Polyester
17.3"
Notebook Compatibility Dimensions
42 cm x 29.5 cm x 4.5 cm
Additional Compartments
Mobile phone, pens, personal accessories
Carrying Strap
Red
Limited warranty: - lifetime
