Dicota Eco Top Traveller BASE 15-15.6"
Quicklinx: G91RWS00 Mfr#: D31325-RPET
£28.00 ex VAT
£33.60 inc VAT
The compact Eco Traveler BASE case offers ideal protection for laptops thanks to its high-density foam (HDF) padding. The case guarantees extra stability and protection with its metal frame, as well as flexible mobility thanks to its lightweight design.
There is an extra compartment in which you can easily store documents. Your smartphone or other smaller items like cables, pens or chargers can be stored in the convenient front pocket, so they are always to hand. The case is comfortable to carry thanks to its neoprene padded carrying handle and it can be attached to a suitcase in seconds with its built-in strap.
You can also carry the case using its adjustable shoulder strap. The Eco Traveler BASE is therefore perfect for you if you are always on the go and want to support the recycling of PET bottles with an eco-friendly case.
DICOTA Eco - notebook carrying case
Notebook carrying case
Product Material
300D RPET polyester
40.5 cm x 8.5 cm x 30.5 cm
800 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
15" - 16" / 38.1 cm - 40.6 cm
High-Density Foam (HDF), padded notebook compartment, elastic fixation straps
Carrying Strap
Grab handle, chest strap, adjustable shoulder strap
30 years warranty
Product Material
300D RPET polyester
40.5 cm
8.5 cm
30.5 cm
800 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 4 cm
Additional Compartments
Documents, mobile accessories, mobile phone, front zippered pocket, power bank, pens
Carrying Strap
Closure Type
Zipper
REACH
Limited warranty: - 30 years
Brand: Dicota
