Dicota Eco Multi Roller SELECT 14-17.3"
Quicklinx: FC30WS00 Mfr#: D31635
Made from high-quality recycled PET, the SELECT collection cares for the planet - ideal for the environmentally conscious consumer, without compromising on quality, functionality or design. The Eco Multi Roller SELECT's main material is made of 16 recycled PET bottles. Designed for daily use. Versatile comfort during transport with smooth-running, interchangeable, quiet and high-quality wheels, a robust telescopic handle, riveted comfort carrying handle and length-adjustable carrying strap with comfortable shoulder padding.
The lockable and padded notebook compartment fits notebooks up to 17.3". It is protected with high-density foam (HDF), EVA corners (foam protection) and a reinforced frame. Includes padded slip pocket made of soft Nylex material for tablets up to 10.5" with a reliable fastening strap. In addition, the trolley includes a separate and removable notebook pocket (up to 15.6") with trolley strap. In the lockable and spacious main compartment, you can store clothes, accessories and other equipment. The front zip compartment contains a workstation for mobile accessories. Underneath, an extra zip pocket is perfect for power supplies and cables.
DICOTA Eco Multi Roller SELECT - notebook carrying backpack/trolley
Notebook carrying backpack/trolley
Product Material
Recycled PET
47 cm x 4 cm x 29.5 cm
3.7 kg
Notebook Compatibility
17.3"
Cord management system, lockable notebook compartment, padded notebook compartment, up 10.5" tablet support
Carrying Strap
Top carry handle, adjustable shoulder strap
Telescopic Handle / Wheels
Product Material
Recycled PET
47 cm
4 cm
29.5 cm
3.7 kg
17.3"
Notebook Compatibility Dimensions
42 cm x 29.5 cm x 4 cm
Additional Compartments
Tablet
Carrying Strap
Closure Type
Zipper, zipper pocket
Lining Material
Ethylene vinyl acetate (EVA)
Wheels Qty
2
