Dicota Cabin Roller Case PRO 14-15.6" - Black
Quicklinx: DR06WS00 Mfr#: D31218
Device Type: Laptop
Type: Case
Device Screen Size: 15.6"
Colour: Black
£116.18 ex VAT
£139.41 inc VAT
Protect your mobile equipment within the practically partitioned interior. The separate notebook case is kept save within the lockable front compartment which offers direct access for baggage screening. Furthermore the front compartment features slip pockets for passports, travel documents, power supply units and cables. An additional external zip pocket holds office and travel accessories. The generous main compartment with integrated TSA lock provides plenty of space for clothing and toiletries. Make use of the fixation straps and inside pockets to organize your belongings. The Cabin Roller PRO is equipped with a built-in address tag and two handgrips on the long and on the short side which help to pull the case out of overhead compartments. All you need to travel without worries to every destination.
DICOTA Cabin Roller PRO - spinner
Spinner
Screen Size Compatibility
15.6"
40 cm x 23 cm x 55 cm
3.9 kg
Luggage Volume
49 litres
Material
Aluminium, polyester
40 cm
23 cm
55 cm
3.9 kg
Material
Carrying Case
Spinner
15.6"
Protection
Stain-resistant, water repellent
Carrying Strap
Trolley strap, top carry handle, side carry handle
Closure Type
Zipper, pin code lock
Additional Compartments
Cable, power adapter, passport, personal accessories, shoes, clothing, tickets, toiletry, address, tablet, internal slip pockets, 2 x front external zippered pockets
Luggage Volume
49 litres
Telescopic Handle
Wheels Included
Inner Dimensions
26.5 cm x 3.5 cm x 38.5 cm
Notebook case
IATA DGR
Lifetime
Dicota Cabin Roller Case PRO 14-15.6 Bundle deal on Dicota Cabin Roller Case PRO 14-15.6" - Black
£215.35
Device Type: Laptop
Type: Case
Colour: Black
Brand: Dicota
Price Range Ex VAT: 100 - 150
