The fitall system separating wall in the notebook compartment lies protectively across your notebook and fits automatically to sizes from 15 - 17.3". The perforated and thus light EVA foam material in the sealable notebook compartment perfectly protects the edges of your device with a remarkable saving in weight. The anti slip technology coating ensures perfect grip for your notebook in the compartment and the adjustable padded shoulder strap. Excellent protection for your iPad or tablet thanks to the EVA-shaped compartment with extra-soft nylex inner lining. Generous storage space for printer, projector and documents in the expandable compartment and in the zip compartment. The front pocket with key fob and insert pockets allows you to organize your personal equipment and provides space for additional mobile accessories. Highest wearing comfort thanks to ergonomic back padding, adjustable shoulder straps, comfortable handle shape and trolley fastening strap. Hidden zip compartment for IDs. Bag bottom made from waterproof material - DICOTA's attention to detail makes this bag one of your most reliable business partners!
- DICOTA Backpack Pro Laptop Bag 17.3" - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Product Material
- Nylon, ethylene vinyl acetate (EVA)
- 44 cm x 20 cm x 32 cm
- 1.4 kg
- Notebook Compatibility
- 17.3"
- Waterproof, adjustable shoulder strap, zipper pocket, padded shoulder strap, elastic strap fastening, slip pocket, molded lockable
- Carrying Strap
- Hand grip, shoulder carrying strap
- Limited lifetime warranty
- Product Type
- Product Material
- 44 cm
- 20 cm
- 32 cm
- 1.4 kg
- 17.3"
- Notebook Compatibility Dimensions
- 42 cm x 29.5 cm x 4 cm
- Additional Compartments
- Mobile phone, cable, power adapter, passport, documents, pens, wallet, business cards, mobile accessories, Apple iPad
- Carrying Strap
- Lockable
- Limited warranty: - lifetime
