Dicota Backpack ECO 14-15.6"
Quicklinx: FC2PWS00 Mfr#: D30675
More than 50 In Stock
£35.88 ex VAT
£43.05 inc VAT
Backpack Eco lets you carry your notebook comfortably, the dedicated removable notebook case with HDF (High Density Foam) which secure the notebook safe during the journey. DICOTA fully supports sustainable material. Therefore most of the notebook cases are made primarily from recycled PET. Recycled PET is a type of polyester that has a considerably lower impact on the environment compared to produced polyester.
Plenty of room in the spacious main compartment for documents and accessories. Cables can be stored in a compartment in the front pocket where you can also place accessories such as pens or mobile phone in the designated compartments. To ensure that you keep going on your journey throughout the day, it has side pockets for umbrella or water bottle and a perfect fit rain cover. For when the rain is pouring the backpack is equipped with a rain cover that is stored in a hidden pocket on the bottom of the bag. Just pull it out and put it over the bag and your belongings are safely protected from moist.
DICOTA Backpack Eco Laptop Bag 15.6" - notebook carrying backpack
Notebook carrying backpack
Product Material
Recycled PET
38 cm x 19.5 cm x 44 cm
900 g
Notebook Compatibility
15.6"
Padded, removable laptop sleeve, moisture-proof, rain cover, adjustable shoulder strap
Carrying Strap
Hand grip, shoulder carrying straps
Product Material
Recycled PET
38 cm
19.5 cm
44 cm
900 g
15.6"
Inner Dimensions
32.4 cm x 26.5 cm x 4 cm
Additional Compartments
Mobile phone, cable, umbrellas, documents, pens, bottle, keys
Carrying Strap
Limited warranty: - lifetime
