Dicota Backpack Dual EDGE Notebook Backpack 13-15.6" - Black
Quicklinx: DR1BWS00 Mfr#: D31526
Simplicity. Functionality. Inspired, contemporary design. These are the guiding principles that define the EDGE product family. Exceptional materials, colors and highlights accentuate your own individual style. The Backpack Dual EDGE convinces by its versatility. The intelligent backpack/toploader combination is designed to fit MacBooks and Ultrabooks but offering maximum protection to other notebooks. The padding made of EVA foam within the notebook compartment perfectly adapts to the contours of your device and an elastic fastening strap keeps your notebook securely in place.
You can easily switch between using it as a shoulder bag and backpack - without compromising on ergonomics. The breathable back padding and the cushioned and length-adjustable shoulder straps ensure comfortable transportation even over longer distances. With just a few simple steps the backpack transforms into an elegant shoulder bag. Therefore simply stow the carrying straps within the back panel and install the padded shoulder strap. A comfortable carrying handle on the long side of the bag provides additional travel flexibility and the functional back panel can be used to attach the Backpack Dual EDGE to a trolley handle - pure mobility. The generous main compartment offers space for documents and features an internal zip pocket for headphones or other accessories. Your tablet (up to 10.5") can be safely stored in the padded slip pocket. The practical and easy-access insert pockets in the front compartment allow you to organize your personal equipment such as cables, business cards, IDs and smartphone. In the additional zip pocket at the front panel other important accessories are to hand at all times.
DICOTA Dual EDGE - notebook carrying backpack
Notebook carrying backpack
Product Material
600D polyester
29 cm x 11 cm x 42 cm
860 g
Notebook Compatibility
15.6"
Notebook Supported Sizes
13" - 15.6" / 33 cm - 39.6 cm
Shockproof, adjustable shoulder strap, elastic fixation straps, padded notebook compartment, padded shoulder straps, front pocket, padded tablet compartment, up 10.5" tablet support
Carrying Strap
Shoulder carrying straps, top carry handle
Product Material
600D polyester
29 cm
11 cm
42 cm
860 g
15.6"
Notebook Compatibility Dimensions
38.5 cm x 26.5 cm x 3 cm
Additional Compartments
Mobile phone, headphones, cable, documents, personal accessories, business cards, ID card, front external pocket
Carrying Strap
Closure Type
Zipper
14.5 litres
Limited warranty: - lifetime
