Devolo WiFi AC USB Adapter
Quicklinx: BTMGWS00 Mfr#: 9707
  • IEEE 802.11n
Upgrade instead of buying something new: Now you can use the latest Wi-Fi 802.11ac technology even on older computers, laptops and Apple MacBooks! You can use the Devolo Wi-Fi Stick ac to upgrade your device to the current Wi-Fi ac standard in no time - the easiest and most cost-effective way to enjoy fast, high-performance Wi-Fi ac! Simply connect the Devolo Wi-Fi stick to a USB - and immediately you have a fast, stable connection. Perfect for interference free HD video streaming and online gaming! Thanks to the compact minimalist design, the tiny Wi-Fi ac stick blends in unobtrusively with any laptop or Apple MacBook. Experience the Wi-Fi standard of the next generation - with the Devolo Wi-Fi Stick ac.
  • Latest Wi-Fi standard - without the need for a new purchase
    The Devolo Wi-Fi Stick ac lets you update your computer or laptop to the faster and more powerful 802.11ac Wi-Fi technology in no time.
  • Self-installing
    Simply connect it to a USB port and go! Increases range and transmission speed, thus ensuring top-performance Wi-Fi reception.
  • Three times faster than n-standard
    Provides fast transfer rates with speeds up to 433 Mbps.
  • Perfect for large data volumes
    Enjoy smooth, stable and interference-free HD video streaming and online gaming immediately.
  • Minimalist design
    Blends in unobtrusively with the look of your laptop or Apple MacBook.
devolo WLAN USB Stick - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
1.4 cm x 1.9 cm x 0.7 cm
Europe
Wi-Fi 5
Data Transfer Rate
433 Mbps
Frequency Band
5 GHz
IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac
Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
3-year warranty
Network adapter
External
USB 2.0
Europe
Wireless
Spread Spectrum Method
OFDM
Data Transfer Rate
433 Mbps
Frequency Band
5 GHz
Max Range Open Space
300 m
Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
Encryption Algorithm
WPA, WPA2
1.4 cm
1.9 cm
0.7 cm
Limited warranty - 3 years
10 - 90% (non-condensing)
