Upgrade instead of buying something new: Now you can use the latest Wi-Fi 802.11ac technology even on older computers, laptops and Apple MacBooks! You can use the Devolo Wi-Fi Stick ac to upgrade your device to the current Wi-Fi ac standard in no time - the easiest and most cost-effective way to enjoy fast, high-performance Wi-Fi ac! Simply connect the Devolo Wi-Fi stick to a USB - and immediately you have a fast, stable connection. Perfect for interference free HD video streaming and online gaming! Thanks to the compact minimalist design, the tiny Wi-Fi ac stick blends in unobtrusively with any laptop or Apple MacBook. Experience the Wi-Fi standard of the next generation - with the Devolo Wi-Fi Stick ac.
Latest Wi-Fi standard - without the need for a new purchase
The Devolo Wi-Fi Stick ac lets you update your computer or laptop to the faster and more powerful 802.11ac Wi-Fi technology in no time. -
Self-installing
Simply connect it to a USB port and go! Increases range and transmission speed, thus ensuring top-performance Wi-Fi reception. -
Three times faster than n-standard
Provides fast transfer rates with speeds up to 433 Mbps. -
Perfect for large data volumes
Enjoy smooth, stable and interference-free HD video streaming and online gaming immediately. -
Minimalist design
Blends in unobtrusively with the look of your laptop or Apple MacBook.
- devolo WLAN USB Stick - network adapter - USB 2.0
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 1.4 cm x 1.9 cm x 0.7 cm
- Localisation
- Europe
- Data Link Protocol
- Wi-Fi 5
- Data Transfer Rate
- 433 Mbps
- Frequency Band
- 5 GHz
- IEEE 802.11a, IEEE 802.11n, IEEE 802.11ac
- System Requirements
- Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8 / 8.1 / 10 (32/64 bits)
- 3-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Localisation
- Europe
- Connectivity Technology
- Wireless
- Spread Spectrum Method
- OFDM
- 433 Mbps
- Frequency Band
- 5 GHz
- Max Range Open Space
- 300 m
- Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- Internal
- Encryption Algorithm
- WPA, WPA2
- OS Required
- 1.4 cm
- 1.9 cm
- 0.7 cm
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
