Now everyone can have a Smart Home.
- Up to four programmable buttons for operating selected Home Control components, e.g. switching all lights on/off or heating on/off.
- Easily control individual Home Control components, groups or scenarios at the touch of a button.
- Versatile installation via adhesive film or screws (included in the box contents). No drilling, no mess!
- Easy installation (2 or 4 programmable buttons) with two different rocker switches.
- Easily programmable via an app or on the computer.
- Individually expandable at any time with other devolo Home Control components.
- Future-proofed thanks to standardised Z-Wave® wireless technology.
- 3-year manufacturer's warranty.
With the devolo wireless Wall Switch, your smart home is more versatile than ever before! Switch your device groups on or off at the touch of a button, finally have the light switch in the ideal place or transfer your entire house to night mode at the touch of a button – the devolo Wall Switch makes it possible! In no time at all it can be positioned anywhere in the home using adhesive foil and can then be completely individually and freely programmed. You may want to install it close to the entrance door – if the switch is pressed when leaving the house, your smart home automatically goes to power save and alarm mode. Or you can switch your audio or home cinema system on and off from the sofa. These are just two of the countless possible scenarios for your completely individual smart home.
devolo makes it easy - making your home into a smart home
The requirements for a modern home have grown. For years, the focus has been on a stable and secure connection for computers and state-of-the-art consumer electronics. Now users are seeking more control over their home, a concept called the "smart home" for short. Existing systems were not particularly attractive for most people. Exceedingly high prices, generally over-complicated operation, time-consuming and expensive installation as well as isolated solutions for each area have left the dreams of a smart home unfulfilled. The world market leader in Powerline home networks is developing devolo Home Control as the first simple home automation solution. -
Easy to retrofit, easy to operate and easy to expand
devolo Home Control offers the core attributes that users are familiar with from the world of dLAN adapters: Easy to retrofit, easy to operate and easy to expand. It is an entirely new solution that encompasses all of the key areas for smart homes. Thanks to its modular design, it can also be tailored to each individual home. This allows devolo Home Control to grow to meet the tasks to hand; it can even be installed piece by piece or modified as needed. -
Basic needs for safety, security, comfort, convenience and energy savings as driving forces
devolo's focus on the basic needs of safety, security, comfort and convenience covers the essential requirements for a smart home. In times of rising energy costs, efficient utilization of energy is an important factor. devolo Home Control harmonizes all of these needs and offers a simple, integrated solution. devolo Home Control will be developed as an independent product portfolio alongside its line of dLAN Powerline adapters. As with its Powerline solutions, the company is building on open architecture based on international standards for Home Control as well.
- devolo Home Control Wall Switch - keypad - Z-Wave
- Product Type
- Keypad
- Connectivity
- Wireless - Z-Wave
- Frequency Band
- 868.42 MHz
- Localisation
- United Kingdom
- 3-year warranty
- 8.3 cm x 1.4 cm x 8.3 cm
- Product Type
- Keypad
- Connectivity Technology
- Wireless - Z-Wave
- Max Range Indoors
- 20 m
- Max Range Open Space
- 100 m
- Frequency Band
- 868.42 MHz
- OS Required
- Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple OS X 10.9 Mavericks, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
- Form Factor
- CR2032
- Included Accessories
- CR2032 battery
- Localisation
- United Kingdom
- Warranty
- 3-year warranty
- IP20
- 8.3 cm
- 1.4 cm
- 8.3 cm
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
