Your basket is empty
Devolo Home Control Wall Switch
Quicklinx: BQZ5WS00 Mfr#: 9505
Type: Keypad
14 in stock
£33.33 ex VAT
£39.99 inc VAT
Standard delivery Delivered within 3-5 working days
Now everyone can have a Smart Home.
  • Up to four programmable buttons for operating selected Home Control components, e.g. switching all lights on/off or heating on/off.
  • Easily control individual Home Control components, groups or scenarios at the touch of a button.
  • Versatile installation via adhesive film or screws (included in the box contents). No drilling, no mess!
  • Easy installation (2 or 4 programmable buttons) with two different rocker switches.
  • Easily programmable via an app or on the computer.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to standardised Z-Wave® wireless technology.
  • 3-year manufacturer's warranty.
With the devolo wireless Wall Switch, your smart home is more versatile than ever before! Switch your device groups on or off at the touch of a button, finally have the light switch in the ideal place or transfer your entire house to night mode at the touch of a button – the devolo Wall Switch makes it possible! In no time at all it can be positioned anywhere in the home using adhesive foil and can then be completely individually and freely programmed. You may want to install it close to the entrance door – if the switch is pressed when leaving the house, your smart home automatically goes to power save and alarm mode. Or you can switch your audio or home cinema system on and off from the sofa. These are just two of the countless possible scenarios for your completely individual smart home.
devolo Home Control Wall Switch - keypad
Keypad
Wireless - Z-Wave
Frequency Band
868.42 MHz
United Kingdom
3 years warranty
8.3 cm x 1.4 cm x 8.3 cm
Keypad
Wireless - Z-Wave
Max Range Indoors
20 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple MacOS X 10.9, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
CR2032 battery
United Kingdom
Battery Required
CR2032
Warranty
3 years warranty
IP20
8.3 cm
1.4 cm
8.3 cm
10 - 85% (non-condensing)
Type: Keypad
Brand: Devolo
Price Range Ex VAT: 0 - 50
