More than just a smoke detector.
- Detects smoke emissions early, without fail, to keep you safe.
- The alarm consists of an acoustic and visual warning signal, as well as text message*, e-mail or app notifications.
- In case of alarm, activates all devolo Smoke Detectors automatically.
- Quick and flexibly positioned.
- Can work together with other Home Control components, for example to turn on the lights in the event of an alarm.
- Individually expandable at any time with other devolo Home Control components.
- Future-proofed thanks to standardised Z-Wave® wireless technology.
- 3-year manufacturer's warranty.
*devolo provides you with 15 free SMS messages. For additional notifications, you can purchase a devolo Home Control SMS pack
Whether you're home or away, you can rely on the devolo Home Control Smoke Detector to let you know if there is smoke build-up in your smart home. When there is a fire, every second counts! The devolo Home Control Smoke Detector alarms you in multiple ways: acoustically via an unmistakable signal sound, visually via an LED light, via text, e-mail or app. When combined with other Home Control components, it can additionally turn on the lights and open the shades, for example.
Thanks to the mobile notification to up to X defined mobile numbers and e-mail addresses, you can react right away and notify the fire brigade, even if you are away (e.g. at work or on holiday). Let the devolo Smoke Detector ensure that your family and possessions are optimally protected at all times. Installation only takes a few minutes!
devolo makes it easy - making your home into a smart home
The requirements for a modern home have grown. For years, the focus has been on a stable and secure connection for computers and state-of-the-art consumer electronics. Now users are seeking more control over their home, a concept called the "smart home" for short. Existing systems were not particularly attractive for most people. Exceedingly high prices, generally over-complicated operation, time-consuming and expensive installation as well as isolated solutions for each area have left the dreams of a smart home unfulfilled. The world market leader in Powerline home networks is developing devolo Home Control as the first simple home automation solution. -
Easy to retrofit, easy to operate and easy to expand
devolo Home Control offers the core attributes that users are familiar with from the world of dLAN adapters: Easy to retrofit, easy to operate and easy to expand. It is an entirely new solution that encompasses all of the key areas for smart homes. Thanks to its modular design, it can also be tailored to each individual home. This allows devolo Home Control to grow to meet the tasks to hand; it can even be installed piece by piece or modified as needed. -
Basic needs for safety, security, comfort, convenience and energy savings as driving forces
devolo's focus on the basic needs of safety, security, comfort and convenience covers the essential requirements for a smart home. In times of rising energy costs, efficient utilization of energy is an important factor. devolo Home Control harmonizes all of these needs and offers a simple, integrated solution. devolo Home Control will be developed as an independent product portfolio alongside its line of dLAN Powerline adapters. As with its Powerline solutions, the company is building on open architecture based on international standards for Home Control as well.
- devolo Home Control Smoke detector - smoke sensor - Z-Wave
- Product Type
- Smoke sensor
- Power Source
- Battery
- Connectivity
- Wireless - Z-Wave
- Frequency Band
- 868.42 MHz
- Localisation
- United Kingdom
- 3-year warranty
- 12 cm x 12 cm x 5.3 cm
- Product Type
- Smoke sensor
- Power Source
- Battery
- Connectivity Technology
- Wireless - Z-Wave
- Max Range Indoors
- 30 m
- Max Range Open Space
- 100 m
- Frequency Band
- 868.42 MHz
- OS Required
- Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple OS X 10.9 Mavericks, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
- Form Factor
- CR123A
- Included Accessories
- CR123A lithium battery
- Localisation
- United Kingdom
- Warranty
- 3-year warranty
- 12 cm
- 12 cm
- 5.3 cm
- 0 °C
- 49 °C
- 10 - 95% (non-condensing)
