Your basket is empty
Devolo Home Control Smoke Detector
Quicklinx: BQZ3WS00 Mfr#: 9504
More than just a smoke detector.
  • Detects smoke emissions early, without fail, to keep you safe.
  • The alarm consists of an acoustic and visual warning signal, as well as text message*, e-mail or app notifications.
  • In case of alarm, activates all devolo Smoke Detectors automatically.
  • Quick and flexibly positioned.
  • Can work together with other Home Control components, for example to turn on the lights in the event of an alarm.
  • Individually expandable at any time with other devolo Home Control components.
  • Future-proofed thanks to standardised Z-Wave┬« wireless technology.
  • 3-year manufacturer's warranty.
*devolo provides you with 15 free SMS messages. For additional notifications, you can purchase a devolo Home Control SMS pack
Whether you're home or away, you can rely on the devolo Home Control Smoke Detector to let you know if there is smoke build-up in your smart home. When there is a fire, every second counts! The devolo Home Control Smoke Detector alarms you in multiple ways: acoustically via an unmistakable signal sound, visually via an LED light, via text, e-mail or app. When combined with other Home Control components, it can additionally turn on the lights and open the shades, for example.
Thanks to the mobile notification to up to X defined mobile numbers and e-mail addresses, you can react right away and notify the fire brigade, even if you are away (e.g. at work or on holiday). Let the devolo Smoke Detector ensure that your family and possessions are optimally protected at all times. Installation only takes a few minutes!
devolo Home Control Smoke detector - smoke sensor
Smoke sensor
Power Source
Wireless - Z-Wave
Frequency Band
868.42 MHz
United Kingdom
3 years warranty
12 cm x 12 cm x 5.3 cm
Smoke sensor
Power Source
Wireless - Z-Wave
Max Range Indoors
30 m
Max Range Open Space
100 m
Frequency Band
868.42 MHz
Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 Lion, Windows 8 64-bit Edition, Apple MacOS X 10.8, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple MacOS X 10.9, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
CR123A lithium battery
United Kingdom
Battery Required
CR123A
Warranty
3 years warranty
12 cm
12 cm
5.3 cm
49 °C
10 - 95% (non-condensing)
