Your outlet becomes smart
- The activation and disabling of connected devices such as lamps, the coffee machine, radio, can be time-controlled.
- Ready to use in no time: simply plug it in between the power socket and desired device.
- Finally, an end to unnecessary and high standby consumption of your devices.
- Measures the power consumption unobtrusively in the background and records it.
- Intuitive operation by browser, and a free app for smartphones and tablets.
- Individually expandable at any time with other devolo Home Control components.
- Future-proofed thanks to standardised Z-Wave® wireless technology.
- 3-year manufacturer's warranty.
Never get cold feet again at your favourite seat. The devolo Room Thermostat provides your own individualised temperature where you actually spend time; after all, you usually don't sit directly next to the radiator. It equalises the temperature gradient between the radiator and your favourite seat. It functions simultaneously as a convenient "remote control" for all connected radiators in one room or on one storey. That's how energy saving is made even simpler with devolo Home Control!
devolo makes it easy - making your home into a smart home
The requirements for a modern home have grown. For years, the focus has been on a stable and secure connection for computers and state-of-the-art consumer electronics. Now users are seeking more control over their home, a concept called the "smart home" for short. Existing systems were not particularly attractive for most people. Exceedingly high prices, generally over-complicated operation, time-consuming and expensive installation as well as isolated solutions for each area have left the dreams of a smart home unfulfilled. The world market leader in Powerline home networks is developing devolo Home Control as the first simple home automation solution. -
Easy to retrofit, easy to operate and easy to expand
devolo Home Control offers the core attributes that users are familiar with from the world of dLAN adapters: Easy to retrofit, easy to operate and easy to expand. It is an entirely new solution that encompasses all of the key areas for smart homes. Thanks to its modular design, it can also be tailored to each individual home. This allows devolo Home Control to grow to meet the tasks to hand; it can even be installed piece by piece or modified as needed. -
Basic needs for safety, security, comfort, convenience and energy savings as driving forces
devolo's focus on the basic needs of safety, security, comfort and convenience covers the essential requirements for a smart home. In times of rising energy costs, efficient utilization of energy is an important factor. devolo Home Control harmonizes all of these needs and offers a simple, integrated solution. devolo Home Control will be developed as an independent product portfolio alongside its line of dLAN Powerline adapters. As with its Powerline solutions, the company is building on open architecture based on international standards for Home Control as well.
- devolo Home Control Smart Metering Plug - smart plug - Z-Wave
- Product Type
- Smart plug
- Environment
- Indoor
- Connectivity
- Wireless - Z-Wave
- Frequency Band
- 868.42 MHz
- Localisation
- United Kingdom
- 3-year warranty
- 5.77 cm x 7.66 cm x 9.45 cm
- Product Type
- Smart plug
- Environment
- Indoor
- Connectivity Technology
- Wireless - Z-Wave
- Max Range Indoors
- 20 m
- Max Range Open Space
- 100 m
- Frequency Band
- 868.42 MHz
- OS Required
- Apple MacOS X 10.6, Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Windows 8 Pro 64-bit Edition, Windows 8 32-bit Edition, Windows 8 Pro 32-bit Edition, Windows 8.1 32-bit Edition, Windows 8.1 64-bit Edition, Windows 8.1 Pro 64-bit Edition, Apple OS X 10.9 Mavericks, Windows 8.1 Pro 32-bit Edition, Ubuntu Linux 12.04
- Localisation
- United Kingdom
- Power Provided
- 3000 Watt
- Warranty
- 3-year warranty
- 0.48 Watt
- 5.77 cm
- 7.66 cm
- 9.45 cm
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
